Finding a hard rear brake line? *searched*
Old Dec 1, 2005 | 10:05 PM
Deo's Avatar
Deo
Default Finding a hard rear brake line? *searched*
Managed to twist the line in half while detaching it from the wheel cylinder, the one in between the wheel cylinder and the rubber line.
A junkyard run isn't really an option, I need it quickly. Does anyone know where I could find one of these? I'm dubious to line repair, but if finding a replacement is going to be a pain (or take more than a day) I'm open to it.
As usual, any input is greatly appreciated, thanks.
Old Dec 2, 2005 | 03:19 AM
88 rex's Avatar
Default Re: Finding a hard rear brake line? *searched* (Deo)
The napa near me has straight brake lines that just need to be bent. I would give that a shot.
Old Dec 2, 2005 | 04:54 AM
CRXDrew's Avatar
any autoparts store has varying lengths of straight brake line. Just gotta bend it a bit and ur good to go. I did exactly what you did to both of my rears.
Old Dec 2, 2005 | 11:18 PM
Deo's Avatar
Deo
Default Re: (CRXDrew)
I've gotten the lines bent and on there, but I'm getting fluid leakage out the top of the fastener. I already stripped one line tightening it down too much, do I need to be using some kind of sealant?
Old Dec 3, 2005 | 05:49 AM
EFSiR's Avatar
isn't this the short line? if so, just get it from the dealer. Shouldn't cost much.
Old Dec 3, 2005 | 10:22 AM
Crx Jimmy's Avatar
Default Re: Finding a hard rear brake line? *searched* (EFSiR)
did you get the proper flare on the line?, you do not need any sealant, when tightened it seals
Old Dec 3, 2005 | 11:27 AM
STREETWERKZ's Avatar
expletive going to napa and trying to bend it yourself, and all these lame answers these guys are giving you.
go to your nearest dealership, get the correct part the first time, and finish it that day.
Old Dec 3, 2005 | 01:42 PM
spoonfedcrx's Avatar
y go the dealership when u can spend like 15 bucks at napa and 20 minutes cutting, bending, and flaring. i work for honda what do u think we do.
Old Dec 3, 2005 | 01:45 PM
Default Re: (spoonfedcrx)
i work for honda also..... so i know what you do....
you go into the parts department and order the correct part.
no technicain goes to napa and bends his own pipes...... TRUST ME.
half the technicians out there are part swappers.... not real mechanics.
BTW, the exact part he needs is less than $80. from the front of the car to the rear brakes..... pre cut, bent, and flared.
Old Dec 3, 2005 | 05:47 PM
Deo's Avatar
Deo
Default Re: (STREETWERKZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">BTW, the exact part he needs is less than $80. from the front of the car to the rear brakes..... pre cut, bent, and flared. </TD></TR></TABLE>
Acually, I needed the ~10" part that goes from the wheel cylinder to the rubber line, bending it was no big deal, and it came pre-flared. The issue is possibly with the flair style, I went over to Napa on my lunch break and the guy suggested trying the other type they had.
I also tried going over to my local Honda dealership, but they decided to close an hour early today, 5 minutes before I got there.
Old Dec 3, 2005 | 08:17 PM
d16dcoe45's Avatar
Default Re: Finding a hard rear brake line? *searched* (Crx Jimmy)
I got new ones from the dealer, they are pre-bent, have the fittings and the rubber coating on them, only like $20 per side. Worth it.
Old Dec 4, 2005 | 09:09 PM
Deo's Avatar
Deo
PIAA310
Honda Civic (2001 - 2005)
11
Mar 5, 2012 01:03 PM
ESP.net
Suspension & Brakes
May 29, 2010 09:19 PM
BlitzSix
12
Jul 1, 2009 10:55 PM
turbospool
Aug 10, 2003 11:38 AM
ill phil
Aug 6, 2003 11:52 PM
