ITB's
Old Nov 27, 2005 | 06:39 PM
evade this honda's Avatar
Default ITB's
I want them but don't know were to get them. plus I need to have some pro's and cons of them
Old Nov 27, 2005 | 06:45 PM
Default Re: ITB's (evade this honda)
I used the search but not enough info for what I want to know
Old Nov 27, 2005 | 08:19 PM
bmw626's Avatar
what motor do you have? Toda makes one for the B-series but they are hella expensive
http://todaracing.com/products....html
Old Nov 27, 2005 | 08:37 PM
EGmikeH22's Avatar
* B A N N E D *
you can make them yourself with stock intake manifold runners and injectors, then just saw off the plenum, add some motorcycle TBs, add velocity stacks, then just rig the TPS.
if you can't do that you don't deserve ITBs
Old Nov 27, 2005 | 09:24 PM
Superdragr45's Avatar
Default Re: (EGmikeH22)
wat motor is this goin on?? mods?? compression u will be running???
Old Nov 27, 2005 | 10:36 PM
97spooncivic's Avatar
Default Re: (Superdragr45)
EGmikeH22 do you have any pics of that? im really interested
Old Nov 27, 2005 | 11:13 PM
vc's Avatar
vc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superdragr45 &raquo;</TD></TR><TR><TD CLASS="quote">wat motor is this goin on?? mods?? compression u will be running???</TD></TR></TABLE>
exactly
don't get itb's if u don't need.. and I hope ur not using them for DD
Old Nov 28, 2005 | 10:24 AM
EGmikeH22's Avatar
* B A N N E D *
Default Re: (97spooncivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97spooncivic &raquo;</TD></TR><TR><TD CLASS="quote">EGmikeH22 do you have any pics of that? im really interested </TD></TR></TABLE>
no, i haven't done this, but just think of what they are, individual throttle bodies. thats it.
there is no real weirdness in them other than the venturi tunnel velocity stacks, I would try and find those premade for optimum flow, but their dimensions would depend on displacment and max RPM more than anything.
I think of them like an intake, you can build it or you can buy it, as long as its not a stressed part of your engine, like a piston / rod / bolts / gasket / driveshaft / most else.... you can make it yourself and see most of the gains...
when you buy a hella expensive set of ITBs you are buying CNCd flanges and CNC injector ports, and fuel rail mounts... all of which your stock IM already has.
H IMs already have places to run direct port nitrous on the underside of the mani.
Old Nov 28, 2005 | 12:21 PM
I have a b16, ctr pistons skunk stage2 cams hondata s200 full fuel setup
Old Nov 28, 2005 | 12:27 PM
Default Re: (evade this honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evade this honda &raquo;</TD></TR><TR><TD CLASS="quote">I have a b16, ctr pistons skunk stage2 cams hondata s200 full fuel setup</TD></TR></TABLE>
sounds like a worthy setup for ITBs..........TWM and Toda are the two best in the field of ITBs. but, IMO, ITBs arent good for a daily driven cars. sure they make good power, but, the gas mileage and idle problems may give u more of a headache than anything........just my .02
Old Nov 28, 2005 | 02:21 PM
white92eg9's Avatar
if u are going to run itbs get hondata to have it tuned best way. or any thing like hondata, aem, motec etc.
Old Nov 28, 2005 | 02:45 PM
EGmikeH22's Avatar
* B A N N E D *
Default Re: (white92eg9)
crome pro has itb tools
Old Nov 28, 2005 | 03:31 PM
jdm123's Avatar
twm makes them you can get them on pretty much any aftermarket honda site. such as modacar.com or jhpusa.com.
snaileg
Sep 7, 2008 08:48 AM
Mostecstreethb
Dec 19, 2007 10:36 AM
95 honda8
Nov 2, 2007 02:10 PM
RSXTYPES0818
10
Dec 28, 2006 06:56 AM
1.8
Jan 30, 2005 06:11 PM
