99 ej8 -> em1 help...
From: University of Massachusetts, Amherst, Ma, US of A
I've been doing a ton of research here on H-T and I need to know what mounts can I use from my d16y8 to my new b16a. I have a 99ex AUTO and I'm going to drop in a B16a manual. I am pretty set on swapping auto to manual its just the motor mount issue. I was told I can reuse the rear tranny mount and driver side mount. Can someone inform me of what mounts I can and cannot use. Thanks a lot
from a 99-00 civic si you need the driver mount (inside the timing belt mount ) the timing belt mount bracket (the one that has 3 holes in it 2 on one side and 1 on the other) for the rear you need the rear mount BRACKET from a 99-00 civic si on the tranny you should be able to use your stock mount ... and the tranny torque mount you will need it from a b series tranny ... if you want to retain your air conditioning you need a P54 ac bracket ..cheapest place to get one is at http://www.icbmotorsport.com you also need the 99-00 civic si throttle cable and i would recomend using the wire harness from a civic si if your car is a 99-00 if not you can use your stock harness ... good luck
RSciviX
Feb 4, 2006 02:55 AM
. Someone has got to know the answer!
