what engine mount and bracket for 99 civic ex
im swapping a gsr motor into a 99 civic ex
for thr drivers side, what engine mount and bracket do i use
do i need the si bracket, and can i use the stock oil filled mount or is it the same as the si's
Re: what engine mount and bracket for 99 civic ex (RSciviX)
you need 99-00 SI rear bracket
SI/GSR front torque mounts
if you want to use the stock gsr mount on the timing belt side you need a hasport or any other brand kit that uses a different bracket.
you can use the stock sohc upper tranny mount and timing belt mount. If you have the 99-00 SI block mount on the timing belt side that is
slambedcivic
11-24-2006 12:33 PM
blackeg
05-02-2005 07:50 AM
