B18B1 stock bottom end with p30's and 125 shot ???
Old Nov 21, 2005 | 03:28 PM
The Stance's Avatar
Default B18B1 stock bottom end with p30's and 125 shot ???
my current set up consists of a b18b1 block with p30's on stock rod bolts and head studs....so my question is with proper tunning can i be reliable with a 125 shot ?? i dont plan on reving past 6500 rpm...
any insight or similiar set up and input would be greatly appreciated......
Old Nov 21, 2005 | 06:50 PM
The Stance's Avatar
come on guys i need some help here......
Old Nov 21, 2005 | 06:54 PM
Zakar's Avatar
yes... if done properly.. it will hold.. i rev my LS to 7 grand so i fall higher in the powerband after the shift... just make sure you dont hit a rev limiter while on juice..
Old Nov 21, 2005 | 06:56 PM
Zakar's Avatar
keep in mind you will have to upgrade your fuel system
Old Nov 21, 2005 | 11:17 PM
The Stance's Avatar
well i want to hit it with as much nitrous as safely possible which is essentially impossible with nitrous....would it be better with its stock ls pistons in place ?? cause i have another ls block sitting...
Old Nov 22, 2005 | 07:04 AM
The Stance's Avatar
BUMP........
Old Nov 22, 2005 | 10:11 AM
JDMisGOOD's Avatar
Default Re: (The Stance)
i'd upgrade atleast the rod bolts.
Old Nov 22, 2005 | 10:15 AM
The Stance's Avatar
why rod bolts and not head ?? also what about using a block guard ?? any fuel system recommendations ??
Old Nov 22, 2005 | 10:24 AM
JDMisGOOD's Avatar
Default Re: (JDMisGOOD)
Block guards are junk. I'd replace rod bolts before headstuds. But it doesn't hurt to run head studs. fuel system upgrades. run a good engine management,fuel pump,and some bigger injectors.
Old Nov 22, 2005 | 03:02 PM
The Stance's Avatar
are we talking larger as in using Prelude injectors or as in using dsm 450's and an s-afc ?? i figured head stud because i thought headgasket leak may become an issue when the motor is under nitrous....
Old Nov 22, 2005 | 03:07 PM
JDMisGOOD's Avatar
More like RC injectors, and Hondata.
Old Nov 22, 2005 | 03:11 PM
The Stance's Avatar
woah umm thats a little out of my budget .....are u sure the dsm 450's and s-afc wont work ??? or perhaps a custom tuned chip i ca npurchase off some one with a similiar setup ??
Old Nov 22, 2005 | 03:41 PM
JDMisGOOD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Stance &raquo;</TD></TR><TR><TD CLASS="quote">woah umm thats a little out of my budget .....are u sure the dsm 450's and s-afc wont work ??? or perhaps a custom tuned chip i ca npurchase off some one with a similiar setup ??</TD></TR></TABLE>
That would work... Not ideal by any means. but yes it would work.
Old Nov 22, 2005 | 08:02 PM
The Stance's Avatar
any tips on tunning this sort of management setup for the amount of nitrous i plan on using??
Old Nov 22, 2005 | 08:32 PM
JDMisGOOD's Avatar
PM cubish
I'm sure he can help you out.
chippy
20
Apr 30, 2020 10:19 AM
SexyEJ8
Dec 12, 2008 06:58 PM
CTM
May 25, 2007 11:49 AM
hondahippy
Jan 18, 2005 08:33 AM
ophdehEEzY
12
Dec 30, 2003 11:37 AM
