High Idle Problem
Old Nov 17, 2005 | 11:53 PM
Dan_the_MaN's Avatar
Default High Idle Problem
Hey guys,
Just installed my RC 440cc injectors and clips(by splicing the wires to the old clips) and installed a new
chipped P06 ECU from Phearable.
Starting the car up, I noticed that I have a high starting idle @ 1500rpm's. The lowest it stays is 1500rpms. It seems to jump a little to 1600 then back down to 1500 and then back up, etc. It does this forever. It sounds like I am pressing the throttle a little, letting off, then pressing it again, over and over. At first I thought I wired something wrong, so I double checked my splicing for the injectors and it seems fine. And the wires are twisted together snugly.
What else could it be?
Btw, Turbo'd D16Y7.
Old Nov 18, 2005 | 01:42 AM
r3dh4tch's Avatar
Default Re: High Idle Problem (Dan_the_MaN)
Make sure you're getting a good seal around where the fuel injectors seal into the intake manifold. If you're not getting a good seal you could have a vacuum leak.
civickiller
May 12, 2010 02:10 PM
cbustuner
Mar 24, 2008 10:38 PM
Topdawgg
Jun 28, 2006 01:03 AM
Dan_the_MaN
Nov 18, 2005 05:24 AM
soopafly828
Mar 15, 2003 07:17 AM
