injector problem/idle problems
Old Mar 9, 2003 | 07:08 PM
soopafly828's Avatar
Default injector problem/idle problems
ok now to the real problem - one of my injector got clogged and i dont have any spare prelude ones lying around and the car is my daily driver - so i borrowed some integra injectors from my friend for the time being - but after installing the new injectors the car idles really high (1500 - 2000) and will never come back down, i raised the fuel pressure and adjusted the idle on throttle body but does not solve the problem. has anyone ever had this problem?
[Modified by soopafly828, 4:23 AM 3/10/2003]
Modified by soopafly828 at 3:43 AM 5/21/2004
Modified by soopafly828 at 3:44 AM 5/21/2004
Old Mar 9, 2003 | 07:32 PM
Default Re: injector problem/idle problems (soopafly828)
nevermind i found out that its normal for it to idle like this w/ the combonation of the motor and injectors
so i really need to get my injectors fixed or get new ones asap
anyone have obd2 plug prelude injectors for sale?
Old Mar 15, 2003 | 07:17 AM
KStuned's Avatar
so you are using obd2 lude injectors, which means no injector resistor box?! The Obd2 lude injectors are only rated to 270cc, and the obd1 lude injectors are supposed to be 345cc, if you are going to be building this thing up, a set of obd1 lude injectors might be a good idea. And if you ever got that route and need and injector resistor box or some injector clips, let me know I have some.
s032105k
Engine Management and Tuning
Apr 12, 2011 10:14 AM
s032105k
Apr 12, 2011 07:56 AM
KooK
Feb 16, 2006 07:14 AM
Dan_the_MaN
Nov 18, 2005 01:42 AM
