High Idle Problem
Old Nov 17, 2005 | 08:28 PM
Dan_the_MaN's Avatar
Default High Idle Problem
Hey guys,
Just installed my RC 440cc injectors and clips(by splicing the wires to the old clips) and installed a new
chipped P06 ECU from Phearable.
Starting the car up, I noticed that I have a high starting idle @ 1500rpm's. The lowest it stays is 1500rpms. It seems to jump a little to 1600 then back down to 1500 and then back up, etc. It does this forever. It sounds like I am pressing the throttle a little, letting off, then pressing it again, over and over. At first I thought I wired something wrong, so I double checked my splicing for the injectors and it seems fine. And the wires are twisted together snugly.
What else could it be?
Old Nov 18, 2005 | 02:42 AM
D@nnY's Avatar
Default Re: High Idle Problem (Dan_the_MaN)
vaccuum leak at the oring seals for the injectors....get a spray water bottle and mist water aroudn the injectors and see if the motor bogs.....
What are you using for engine managemnet? the idle air control duty cycle mihgt be hgih on the program
Old Nov 18, 2005 | 05:24 AM
93CX's Avatar
Default Re: High Idle Problem (D@nnY)
if all you touched was the injectors, its safe to say its a leak in the oring. check that first
or of course a preprogrammed ecu would cause idle to go crazy
civickiller
Jun 6, 2026 07:54 PM
cbustuner
Mar 24, 2008 10:38 PM
8YourV8
Nov 17, 2006 11:57 AM
KooK
Feb 16, 2006 07:14 AM
Dan_the_MaN
Nov 18, 2005 01:42 AM
