2002 Accord Intermittent Horn Failure
Old Nov 15, 2005 | 05:43 PM
JeffV1000's Avatar
Default 2002 Accord Intermittent Horn Failure
My 2002 Honda Accord has developed an intermittent horn failure problem. When I turn my steering wheel in either direction, the horn will work. When I keep the steering wheel straight, the horn stops working. When I make a turn onto another street and then drive straight, the horn will work until I turn the wheel slightly such as drive around a parked car. Is it the cable reel, bent horn plate, or something else?
Old Nov 15, 2005 | 05:58 PM
Ross 2.0's Avatar
In a Junkyard near you.
Sounds like a cable reel. Are you getting an SRS light, or if you have cruise contol is that acting up too?
Old Nov 15, 2005 | 06:14 PM
JeffV1000's Avatar
Default Re: (MooGoCow3)
I am not getting an SRS light. I rarely use my cruise control so I am not sure if it is working properly. Is a cable reel expensive and difficult to install?
ScottF
10
Sep 1, 2009 05:50 PM
nickoz
May 11, 2009 01:14 PM
BlitzSix
13
Apr 6, 2009 01:49 PM
Degameth
Honda Civic (2001 - 2005)
Feb 28, 2007 08:00 PM
BlazingSIRT
May 8, 2003 05:17 AM
