Just how bad for a motor is "running out of gas"
Old Mar 11, 2002 | 11:28 AM
OneThirtyEight's Avatar
Default Just how bad for a motor is "running out of gas"
Lately ive been pushing it REAL close to running out of gas since im like broke. ANyways how bad for a motor would this be? Esp. like my motor built and around 11.5:1 compression, I know it couldent be good but could it actually lean out right before it runs out causing detonation?
Old Mar 11, 2002 | 12:42 PM
boosted1993fd's Avatar
Default Re: Just how bad for a motor is "running out of gas" (97blackteg)
I've heard it puts more of a strain on the fuel pump when it starts to get real low like that...not sure if it could lean it out like the way you were saying...anyone else want to add to this?
Old Mar 11, 2002 | 01:14 PM
ingrate's Avatar
25 Year Member
Default Re: Just how bad for a motor is "running out of gas" (Interlude)
all that crap from the bottom of your gas tank is being sucked into your engine. you should replace your fuel filter afterwards if you actually did let it run out of gas
Old Mar 11, 2002 | 02:39 PM
Armed Ferret's Avatar
Default Re: Just how bad for a motor is "running out of gas" (In7egrity)
isn't the pump already in the lowest possible spot on the tank? so therefore "all that crap" would already get sucked into one's engine.....
iono.....just a thought.
Old Mar 11, 2002 | 02:42 PM
Rtzx9r's Avatar
GDD 1%
I've run my lawnmower out of gas 8 billion times and it's still goin. The worst part is that it does suck up all the junk in the gas tank.... thats the worst part. I think doing it on adiesel is far worse due to the high pressure fuel systems.
Old Mar 11, 2002 | 03:29 PM
Mr.Rab's Avatar
Ok think about this you come home and turn off your enginev off, wouldn't the same thing happen if you ran out of gas??? Yes nothing bad happens. And if you are going to shoot back with a question like well what if I'm driving along at at around 3 of 4 rpms and then I run out of gas? Well think of it this way pushing the clutch in at 3 gear, shifting into N, almost the same thing happens except your engine doesn't stop. NOTHING BAD HAPPENS IF YOU RRUN OUT OF GAS. I did with a 1986 944 Turbo Porshe and it was running fine the other day.
Old Mar 11, 2002 | 04:20 PM
Phat Corolla's Avatar
New User
Default Re: Just how bad for a motor is "running out of gas" (RAB_01_GSR)
Yes...it doesn't hurt it...not as far as I know at least. It makes no sense why it would be harmful.
Old Mar 11, 2002 | 05:30 PM
Mr.Rab's Avatar
Default Re: Just how bad for a motor is "running out of gas" (Teken)
Teken knows everything, he helped me out with Adhesive tape, by the way I got some good 3M stuff at Home Depot.
Old Mar 11, 2002 | 06:35 PM
Regular Series's Avatar
So what is a good cleaning agent that will remove old glue without harming the finish?
And is it my imagination, or does my overall fuel efficiency drop if I run the tank down?
Old Mar 12, 2002 | 04:41 AM
Bagged!
Old Mar 12, 2002 | 05:27 AM
incogNitto's Avatar
Fuel surrounding your fuel pump also cools it. If your running on empty, the fuel originally around your pump cooling it is now being used and you risk damage to your pump.
-Chet
[Modified by Sleepy186, 9:29 AM 3/12/2002]
Old Mar 12, 2002 | 05:35 AM
virginia_dude's Avatar
Default Re: Just how bad for a motor is "running out of gas" (Sleepy186)
I agree, mechanics will tell you that a pump running dry has nothing to cool it and will damage it. It normally is sbmerged in gassoline that keeps it cool, if it sucks air it runs faster trying to pump something and at the same time has nothing to draw off heat generated.
Old Mar 12, 2002 | 05:27 PM
Default Re: Just how bad for a motor is "running out of gas" (virginia_dude)
I actually get decent mileage... ~29 mpg in the winter, mostly highway, some city. I'll get one or two more mpg in warmer weather. I asked only because it seemed like I'd get a better mpg average when I filled up a little sooner.
4doorekITR
Oct 5, 2007 05:02 PM
Dave4282
May 13, 2007 06:25 PM
dizzyroc88
25
Dec 2, 2006 05:13 AM
mingbling96
Jul 19, 2006 09:52 AM
alleyezonme
Jan 14, 2006 06:57 PM
