B16A2 in a 95 GSR??
B16A2 in a 95 GSR??
Ok got a 95 GSR shell with all stock wiring under hood. Will a 99 Si motor b16a2 wire up directly with out a problem?
Can I used GSR wiring harness or do I need the 99 Si wiring.
Looking for a plug and play set up. No cutting ot splicing.
For the motor to be plug and play into your car, you need to get an obd1 distributor and fuel injectors. Everything else should be plug and play basically.
RC_Benjamin
Mar 14, 2006 05:44 PM
fckmnky69
Mar 4, 2005 09:50 PM
