engine swap problem
engine swap problem
i have a 94 civic si. i have a 99 gsr motor. i have a problem. i have asked many different people on how to make the 99 motor work with the car without cutting and splicing all through the 99 engine wiring harness. i have also aquired an obd-1 gsr ecu. any help would much appreciated.
Re: engine swap problem (FrankEXsteiN)
Easy: Plug the GSR harness into your harness as is and get a P28 "kenji" spec ECU with GSR appropriate maps.
More details should be available from B18C5-EH2. IM him for more details - he has done this.
Hard (but right) - convert the 99 spec to 95 spec. Get an OBD-I distributor, or "re-pin" the distributor to OBD-I specs (sorry, I can't tell you how to do that, either). Use a 95 GSR harness, and 95 GSR O2 sensor, and plug it right up.
I BELIEVE, although I don't know for sure, that the Si already has the knock sensor. I CANNOT find it in my 1992 Helms service manual, so I could be full of crap. The worst thing that could happen is you'd have to wire one wire from the engine harness to the ECU.
My $0.02? I did it the hard way. This was more parts, and might be more difficult. I didn't know about the easy way, and I think that might be worth doing, rather than the hard way.
Shawn
Re: engine swap problem (chainsaw)
i'm a little late on this one so bare with me, you should convert everything from 99 to 95... after that its plug and play.... saves you the headache
good luck
good luck
JDMfreak81
04-03-2018 03:46 PM
