Tranny swap wiring??
Old Nov 11, 2005 | 08:13 PM
f22pwrdaccord's Avatar
Default Tranny swap wiring??
I have a 96lx non-vtec 5spd parts car and am swaping into a 94 ex vtec auto what will i need to do about wireing it up cant find this info anywhere?
Old Nov 12, 2005 | 04:39 AM
Default Re: Tranny swap wiring?? (f22pwrdaccord)
anyone??
Old Nov 12, 2005 | 09:44 AM
up
Old Nov 12, 2005 | 01:21 PM
alright well is there anyway I can trick the car into thinking its in neutral all the time?
Old Nov 12, 2005 | 03:34 PM
JDMcb7's Avatar
Easy as pie what i did with my auto to manual swap was short out the 2 wires on the shifter bored(where the automatic shifter is and put the 2 "park" wires together fool the car that your always in park.. and that way you dont have to take out the key lock soliniod out either.. hope this gives you a general idea.. heck i think dealing wihtthe wiring was the easyest part of the auto to manual swap
Old Nov 13, 2005 | 06:54 AM
Default Re: (JDMcb7)
alright so just splice the 2 park wires together so that they are conected and thats it?
Old Nov 13, 2005 | 10:23 AM
raceACCORDingly's Avatar
should have done a search... there are quite a few of threads on manual conversions.
https://honda-tech.com/zerothread?id=1237137
theres a real easy way... under the automatic shifter theres a selector switch. put that pin in the switch all the way to park and thats it (or look up the color on the wires for park and splice them). this way bypasses the clutch switch so you can take the key out w/o having to wire up the clutch switch. if you are going to wire in the clutch switch then put the pin to neutral or splice the neutral wires.
are you swapping the entire 96 LX motor into the 94 EX?
Modified by raceACCORDingly at 11:48 PM 11/13/2005
Old Nov 13, 2005 | 11:45 AM
Default Re: (raceACCORDingly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceACCORDingly &raquo;</TD></TR><TR><TD CLASS="quote">should have done a search... there are quite a few of threads on manual conversions.
theres a real easy way... under the automatic shifter theres a selector switch. put that pin in the switch all the way to park and thats it (or look up the color on the wires for park and splice them). this way bypasses the clutch switch so you can take the key out w/o having to wire up the clutch switch. if you are going to wire in the clutch switch then put the pin to neutral and splice the neutral wires.
Modified by raceACCORDingly at 7:37 PM 11/13/2005</TD></TR></TABLE>thanks i searched but kept coming up as an error so thought i just post it..but im only using the lx for the pedals linkage starter and all that misc. stuff.
Old Nov 13, 2005 | 02:49 PM
sounds good...
DA9Sleeper
Aug 10, 2010 10:44 AM
vietnamezerice
Sep 24, 2008 09:18 PM
addiction2bass
11
Jul 23, 2008 03:57 PM
98exturd
Jul 12, 2007 04:59 PM
LS-T
Jul 3, 2002 11:13 AM
