why does my compresser wheel stop when im at idle???
he my turbo started leaking oil out of the compresser side and i could not figure what it was untill like a few min ago i go to look at the compresser side and the damn turbine is not spinning, but it move if i get it alittle bit of gas
guys any suggestions will work
**** man, i dont think that is any good. mine spins lik a champ @ idle. u could have messed up the bearings & shaft when it was leaking oil. i have never seen a turbo that did'nt spin @ idle. i would call the company that makes ur turbo and get an answer from them too.
yea i think im going to have to do that cause i cant ride with my stuff messed up but i have a hx35W turbo but it requires a different 5 bolt flange and a rebuild
Ahhhh.....the weekly why doesn't my turbo spin at idle post......
I mean seriously...
I mean seriously...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted-EG6 »</TD></TR><TR><TD CLASS="quote">i have a hx35W turbo but it requires a different 5 bolt flange and a rebuild</TD></TR></TABLE>
Just unbolt the turbine housing from the center cartridge. Then get a smaller plate of steel, drill holes that line up to those on the turbine housing, then bolt it up. You then have a functional system, just without the exhaust moving past any vanes. Rebuild turbo at your leasure.
My t3 60-1 .82ar does not spin at idle either on my k-series. A local mechanic who is certified yada yada said it had to do with my oil feedline being to small (-3an). HAHA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 »</TD></TR><TR><TD CLASS="quote">Ahhhh.....the weekly why doesn't my turbo spin at idle post......
I mean seriously...
Why can't people make sure that search is working before being a smart-***
I mean seriously...
</TD></TR></TABLE>Why can't people make sure that search is working before being a smart-***
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeaQuake »</TD></TR><TR><TD CLASS="quote">
Why can't people make sure that search is working before being a smart-***?
If you search I bet you'll find your answer.
b/c replying with "SEARCH" gives them an extra post count
DelSolMike
Mar 9, 2007 08:30 AM
