All-Motor Specs
Old Nov 10, 2005 | 03:30 PM
cltitus's Avatar
Default All-Motor Specs
For those that run all motor ITR's could you give me a heads up what kinda hp/tq im looking at and keeping it street legal.
Could you show me your setup/dyno runs just as a starting block.
So far that all i have done is a stroker kick 2.1L 84mm Bore x 92mm Stroke and Darton Sleeved for added protection.
PLEASE TURBO USERS DONT SPIT OUT THAT TURBO IS BETTER THANK YOU
Old Nov 10, 2005 | 04:15 PM
cltitus's Avatar
Come on i know there alot of all motor heads out there
Old Nov 10, 2005 | 04:21 PM
ZygSpeed's Avatar
Default Re: (cltitus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cltitus &raquo;</TD></TR><TR><TD CLASS="quote">Come on i know there alot of all motor heads out there</TD></TR></TABLE>
https://honda-tech.com/zeroforum?id=44
BTW -- IBTL
Old Nov 10, 2005 | 04:28 PM
Reid's Avatar
Global Moderator
Default Re: All-Motor Specs (cltitus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cltitus &raquo;</TD></TR><TR><TD CLASS="quote">So far that all i have done is a stroker kick 2.1L 84mm Bore x 92mm Stroke and Darton Sleeved for added protection.</TD></TR></TABLE>
What compression are you running? Is this your new setup?
What happened to this setup?
Old Nov 10, 2005 | 04:46 PM
cltitus's Avatar
Right now its running 12.5:1 with a spoon head gasket 12.8:1
Old Nov 10, 2005 | 04:47 PM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cltitus &raquo;</TD></TR><TR><TD CLASS="quote">Right now its running 12.5:1 with a spoon head gasket 12.8:1 </TD></TR></TABLE>
What is the rest of the current setup? What kind of whp is it putting down in its current state?
What happened to the old setup?
Old Nov 10, 2005 | 05:05 PM
cltitus's Avatar
old setup was stock but the crank spun because the mech desided the crank didnt need to be rebalanced and it spun the bearing again so crank was fucked so the 1800 to repair we go back and bought the bore and stroker kit i had extra money for the darton sleeving though
Old Nov 10, 2005 | 05:20 PM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cltitus &raquo;</TD></TR><TR><TD CLASS="quote">old setup was stock but the crank spun because the mech desided the crank didnt need to be rebalanced ...</TD></TR></TABLE>
Rebalancing or not really has precious little to do with spun bearings!
Old Nov 10, 2005 | 05:48 PM
Circuit Star-29's Avatar
Default Re: (zygspeed)
You know, Im skeptical of validity of these claims you make about your engine/s and their configurations. Joo should post some pix.
Old Nov 10, 2005 | 10:20 PM
Pompiuses's Avatar
https://honda-tech.com/zerothread?id=1426425
Old Nov 10, 2005 | 10:36 PM
Haleiwa-Brando's Avatar
Default Re: All-Motor Specs (Pompiuses)
My R is 84mm bore w/ something around 11.8 to 12.0 compression, Rocket Motorsports Rods. Mugen intake, stock timing, stock cam placement, stock header, 550cc injectors and it put something down like 190whp and 140trq. Marshal knows. He did it.
Hytech header is ordered, MX22's are ordered. Proper tuning with the cams, timing, and ECU we're expecting high 220's to low 230's at the wheels. Who knows.
Old Nov 10, 2005 | 10:44 PM
jisu009's Avatar
Default Re: All-Motor Specs (Haleiwa-Brando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">Marshal knows. He did it.
Gee thanks
Old Nov 10, 2005 | 10:48 PM
totsie7944's Avatar
sick caR man.. Really nice build. I should make about 215 wheel with my setup on Wednesday coming up... Toda spec C's cam gears, CTR pistons 12:1 CR. Toda valve train, TI retainers... etc. I willl be posting up the graph.
Old Nov 10, 2005 | 11:44 PM
Default Re: All-Motor Specs (jisu009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jisu009 &raquo;</TD></TR><TR><TD CLASS="quote">
Gee thanks</TD></TR></TABLE>
I ment he did the dyno stuff!!! Hahahaha.
Old Nov 11, 2005 | 07:33 AM
DIFFUT'S INC.'s Avatar
whats your motor specs. compression,cams, and what work was done to the head. if u want pm me and ill help you out the best i can .
Old Nov 13, 2005 | 03:05 PM
cltitus's Avatar
Default Re: (C-speed Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-speed Racer &raquo;</TD></TR><TR><TD CLASS="quote">You know, Im skeptical of validity of these claims you make about your engine/s and their configurations. Joo should post some pix. </TD></TR></TABLE>
this time pictures are in he mail jus waiting to get them last time it took 2 months to get here
Old Nov 13, 2005 | 04:30 PM
program's Avatar
stock everything exept: comptech race header, street exaughst w/ propper addapter, comptech intake and hondata and thats it. 189.5 whp, 14 flat spinning the wheels through first. Oh ya 95k miles and counting.
vipcivic
Honda S2000
39
Aug 4, 2008 04:49 PM
blade0313
19
Jul 17, 2007 11:42 AM
BiG DaDDy O
13
Sep 23, 2004 04:23 PM
Arch-Angel
Jul 8, 2004 07:56 PM
93hatchin
Feb 25, 2004 06:08 AM
