removal of shift link pin
Old Nov 8, 2005 | 01:47 PM
SHG_EasyE's Avatar
Default removal of shift link pin
how do i get the pin out holing the shift link to the tranny?
Old Nov 8, 2005 | 01:49 PM
. O M E G A's Avatar
3rd g3aR vTak
Default Re: removal of shift link pin (spoonjdmdc2)
Hammer , dowl rod !
Old Nov 8, 2005 | 01:50 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: removal of shift link pin (omega02379)
Hammer the hell out of it. You can use an 8mm punch or you can use the 1/8" rathet extension as a punch. It fits in there perfectly.
LShatchie's Avatar
best bet is to use a air chisel, if not Ive found a a/c bolt to work best because of the tapered end...
Old Nov 8, 2005 | 02:32 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: removal of shift link pin (LShatchie)
use a tapered punch, if you're chancing your clutch and droppin the tranny, don't bother hammering it from underneath, just pull it down with the trans and hammer the expletive out of it when it's on a bench, it's easier that way.
Old Nov 8, 2005 | 02:35 PM
nocturnaldragon's Avatar
Default Re: removal of shift link pin (BrokeAssPinoy)
If you do that, remember to remove the other side of the linkage from the car first Theres a tool now made for air chissels to remove the bitch pin.
Old Nov 8, 2005 | 02:38 PM
IlIkEg's's Avatar
Default Re: removal of shift link pin (nocturnaldragon)
1-Hammer
1-Punch
Just hit the Bitch!!!
Old Nov 8, 2005 | 02:50 PM
randys's Avatar
race-lines.com
ac bolt works good for me too
Old Nov 8, 2005 | 03:51 PM
transpar_nt's Avatar
Default Re: (randys)
I find swearing a whole lot helps a bit
Old Nov 8, 2005 | 04:28 PM
del Slo SiR's Avatar
Default Re: removal of shift link pin (delSolSiR626)
I used a small socket with an extension and hit it with a hammer
Old Nov 8, 2005 | 04:32 PM
herbalist's Avatar
i couldnt get it out when i tried with a punch and hammer, it just expanded it even more, either get a bolt that is the exact same size (i've heard the ac bolts fit well, as stated previously) but its not hard to just drop the shift linkage down, its actually probably faster, thats what i did when i changed my clutch
Old Nov 8, 2005 | 04:55 PM
kkim's Avatar
https://honda-tech.com/zerothread?id=470849
Old Nov 8, 2005 | 05:07 PM
doublejz's Avatar
Default Re: removal of shift link pin (kkim)
i use an air chisel with a small round point bit. it blows it right out
Old Nov 8, 2005 | 05:44 PM
SHG_EasyE's Avatar
Default Re: removal of shift link pin (doublejz)
alright thanks for the ideas ill try the ac bolt and hammer first, if that doesnt work im pullin the motor so ill just drop the tranny first and do it that way
Old Nov 8, 2005 | 05:47 PM
Soccerking3000's Avatar
i would also suggest not putting a bitch pin back in, i put a lock nut and bolt in there and ti makes it 10000x easier to get out
Old Nov 8, 2005 | 05:54 PM
SHG_EasyE's Avatar
Default Re: removal of shift link pin (Soccerking3000)
word up- good call
Corksil
12
Dec 29, 2009 10:14 PM
thundernutz
Sep 27, 2009 04:22 AM
z6hatchboy
16
Aug 6, 2009 07:59 AM
spens 91 Ef
19
Jan 8, 2009 07:14 PM
Steve Berman
12
Feb 19, 2003 07:30 AM
