A 57 Trim in a .50 Housing T3/O4E
Old Nov 8, 2005 | 06:06 AM
doc's Avatar
doc
Default A 57 Trim in a .50 Housing T3/O4E?
Is it really possible that in a T3/O4E Turbo with .50 Compressor housing a 57 Trim wheel is installed?
Everytime i read about 57 Trim, ppl speak about .60 compressor housing?!
How can i recognize which trim is it really?
BTW. Wheel outer diameter is 3", inner diameter is 2.28". Compressor housing inlet is 3", outlet 2".
My guess is, it's a 54 Trim!?
Thank you for your help,
Christian
Old Nov 8, 2005 | 06:10 AM
Pay2play killa's Avatar
Default Re: A 57 Trim in a .50 Housing T3/O4E? (doc)
i have a .5ar 57 trim to4e compressor
they're quite common actually
Old Nov 8, 2005 | 06:29 AM
RacerXI's Avatar
Default Re: A 57 Trim in a .50 Housing T3/O4E? (Pay2play killa)
I've got one too.
Old Nov 8, 2005 | 06:43 AM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doc &raquo;</TD></TR><TR><TD CLASS="quote">Is it really possible that in a T3/O4E Turbo with .50 Compressor housing a 57 Trim wheel is installed?
Christian</TD></TR></TABLE>
The trim is just the ratio of inner diameter to outer diameter. To find your turbo's trim you divide 2.28^2 by 3^2, OR 2.28x2.28 divide by 3x3. Then you take the result and multiply by 100.
2.28 x 2.28 = 5.1984
3 x 3 = 9
5.1984 / 9 = 0.5776
0.5775 x 100 = 57.76 or 57.76 trim
Now as far as the wheel being able to fit, the inner portion of the housing just has to be machined to match the fans shape. I dont know what kind of clearances are required for that though. But any shop that specializes in turbos should be able to figure that out for you. Either contact Precision turbos, Garrett, Turbonetics, or maybe send an IM to TheShodan.
Modified by BlueShadow at 8:21 AM 11/8/2005
Old Nov 8, 2005 | 07:00 AM
doc's Avatar
doc
Default Re: A 57 Trim in a .50 Housing T3/O4E? (BlueShadow)
Wow! Great! That's excalty the information what i was looking for.
Thank you!
Christian
Old Nov 8, 2005 | 07:24 AM
BlueShadow's Avatar
np, I fixed my post though.
On the last part I meant to say the inner portion of the compressor housing has to be machined to match up with the shape of the fan. Having a wheel too big to fit into the inner housing would obviously cause metal to metal contact. But I dont know what kind of performance losses you would see if the wheel was too small for the inner part housing.
Old Nov 8, 2005 | 07:26 AM
8200RPM's Avatar
local hippie
Default Re: A 57 Trim in a .50 Housing T3/O4E? (RacerXI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacerXI &raquo;</TD></TR><TR><TD CLASS="quote">I've got one too. </TD></TR></TABLE>
dont lie.
Del_Slowest
Nov 9, 2004 08:42 AM
BoostedD15B7
Mar 24, 2003 10:08 AM
Zero_son
Mar 5, 2003 08:12 AM
ls-t del sol
Feb 22, 2003 01:36 PM
4U2NV
Dec 29, 2002 11:06 AM
