LS/VTEC DONE!!!11
but theres some probs.....im running stock p72 obd2....no nox on the block and im running 310cc injectors...will that cause my car to be boggley??....i hope so because the things im gettin to fix it is.... obd1 gsr injectors, obd1 chipped p28, and jumper harness...its like a fuel boggley feeling....im guess the stock ecu cant read the nox and the bigger injectors??....what do you guys think?? thanx!
nox = ? knock?
Yeah you kinda need a program set to run those 310 injectors. Get your p28 with a good basemap on it, mtber of phearable.net is who i used. It will run like crap with a stock ecu and i wouldn't reccommend it. It could run lean or too much timing, just not good overall. Get a good basemap for your investment, then tuning.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjay8604 »</TD></TR><TR><TD CLASS="quote">nox = ? knock?
Thanks for the referral
</TD></TR></TABLE>Thanks for the referral
im planning on getting stock gsr injectors...only becaues i kno chipped ecu tend to dump fuel anyway so ill just get a p28 chipped with a good base map.....so is it running like crap because it cant read knock also?
I don't quite understand the knock situation, are you saying the knock sensor isn't connected? If so, that'll throw a code, and it will run crappy, because the ECU will retard timing and probably put the ECU in limp mode, where it sets a rev limit to protect the engine.
yea there is no knock sensor on the block.....ok so no wonder its running shitty...and too big of injectors for stock ecu.....so will gettin a p28 help and oem injectors?....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorto85 »</TD></TR><TR><TD CLASS="quote">Definitely get a ECU from mtber... cant get a better basemap around! Mine runs great!</TD></TR></TABLE>
Thanks
Thanks
the soL that could
30
Apr 28, 2006 10:14 AM
