LS/VTEC OBD1 what ECU is the best?
Old Sep 22, 2003 | 06:25 PM
flat-blk-HB's Avatar
Default LS/VTEC OBD1 what ECU is the best?
I am soon to be putting my LS vtec in my 92 Civic..I took it out of my 88 which I used a Pr3 ECU to run it. I was told that running the P72 is not a good idea? But I dont understand why?
Old Sep 22, 2003 | 06:39 PM
mmuller's Avatar
Mad Scientist
Default Re: LS/VTEC OBD1 what ECU is the best? (flat-blk-HB)
what kind of head are you using?
Old Sep 22, 2003 | 06:40 PM
poison's Avatar
I would personally run a P28 with Hondata or a chip, due to the LS not having a knock sensor, the P28 doesn't require it.
The P72 will be fine, but you will throw code 23 for KS unless you have that chipped as well with removed KS.
Old Sep 22, 2003 | 06:47 PM
PHiZ's Avatar
Default Re: LS/VTEC OBD1 what ECU is the best? (poison)
Chipped/tuned P28 number one. Number 2, P61?
-PHiZ
Or a P75 with vtec controller?
Old Sep 22, 2003 | 07:01 PM
Default Re: LS/VTEC OBD1 what ECU is the best? (PHiZ)
I will be running a Knock sensor
Old Sep 22, 2003 | 07:03 PM
poison's Avatar
If you have a KS, then the P72 will be just fine.
Old Sep 23, 2003 | 03:50 AM
Good thanks...
1badteg
Jan 6, 2007 11:23 PM
KillaB18
Apr 12, 2005 07:29 PM
99EletronblueSI
Oct 19, 2004 11:13 PM
intezn
Jan 27, 2003 11:40 PM
IdotheSHOCKER
May 30, 2002 12:31 AM
