act 4puck ?? bad or good?
Question? I s it true that act 4 puck will eat up my toda flywheel and expletive up my Tranny?
because im in need of a new clutch an found a 4 puck unsprung for cheap and was thinking of getting it but trying to do research first.
Let me know Guys?? asap thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cpforyou »</TD></TR><TR><TD CLASS="quote">I've owned a 4 Puck, 6 Puck, 6 Puck w/ Spring....
I love the 6 Puck ACT over the 4 Puck Version.</TD></TR></TABLE>why?
my 6 puck ACT ate through the PP and flywheel within about 8000 miles. well, the chatter that was experienced wit hthe pucked clutch, i elimited by revving and slipping it higher... apparently that'll wear out a pucked clutch way before any organic.
so if you get it, prepare to have some "not smooth" driving or else it'll rip through your flywheel fast. and since you have a lightweight flywheel, im sure it'll be even more rough.
i suggest getting an act XTSS. bet clutch, and i'll never run anythign else in any honda i own.
oh serious.. hm i thought about both 4 or 6 an decided not to get Neither 1 an instead got a Exedy twin plate/ thanx for all the info GUys.
here go some pics of the clutch.
unless you're making atleast 350ft/lb at the flywheel something like that is overkill. and im assuming you're running a turbo setup or you're making a dedicated drag car and looking for long term reliability.
for this guy, stay away frlom pucks.
tell us more about your setup. if you plan on just dragging this car or only driving it on the weekends and putting about 200-250 ftlb of torque to the ground, go for the 4 or 6 puck, they're cheap and hold a lot of tq. But if this is your daily driver stay the hell away from any puck type clutch and spend the extra 50 bucks on a sprung organic disc. get an act hdss or xtss some other type of sprung disc, your wheels will be hoppin over the ground with a puck type clutch; they're just not ideal for the daily driven street.
damn.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreIudeSI »</TD></TR><TR><TD CLASS="quote">tell us more about your setup. if you plan on just dragging this car or only driving it on the weekends and putting about 200-250 ftlb of torque to the ground, go for the 4 or 6 puck, they're cheap and hold a lot of tq. But if this is your daily driver stay the hell away from any puck type clutch and spend the extra 50 bucks on a sprung organic disc. get an act hdss or xtss some other type of sprung disc, your wheels will be hoppin over the ground with a puck type clutch; they're just not ideal for the daily driven street.</TD></TR></TABLE>
for dragg only. *weekends* my set up is a fully built gsr Sleeved 85 8:4:1 comp Full race turbo set up sc61 ramhorn mani 3" dp mandrel bend Pipes Gude Head . list goes on..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reddohcvtec »</TD></TR><TR><TD CLASS="quote">Damn..Nice clutch! How much did that run u if u dont mind me asking?</TD></TR></TABLE>
thanx it was pretty pricey the clutch i got it for 1200$
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by out of order »</TD></TR><TR><TD CLASS="quote">thanx it was pretty pricey the clutch i got it for 1200$
Nice! not too bad, hopefully it will last u a while
</TD></TR></TABLE>Nice! not too bad, hopefully it will last u a while
