act 4puck ?? bad or good?
Old 11-04-2005, 03:07 AM
OUT OF ORDER ROB's Avatar
Default act 4puck ?? bad or good?
Question? I s it true that act 4 puck will eat up my toda flywheel and expletive up my Tranny?
because im in need of a new clutch an found a 4 puck unsprung for cheap and was thinking of getting it but trying to do research first.
Let me know Guys?? asap thanx
Old 11-04-2005, 07:31 AM
boostedhb's Avatar
Default Re: act 4puck ?? bad or good? (out of order)
i haven't had problems with mine
Old 11-04-2005, 08:46 AM
cpforyou's Avatar
I've owned a 4 Puck, 6 Puck, 6 Puck w/ Spring....
I love the 6 Puck ACT over the 4 Puck Version.
Old 11-04-2005, 08:52 AM
93civic_sedan's Avatar
I had an ACT 6 puck in my b16 CRX and loved it I may get another for my hatch.
Old 11-04-2005, 08:54 AM
eg6cusco10pt's Avatar
Default Re: act 4puck ?? bad or good? (cpforyou)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cpforyou &raquo;</TD></TR><TR><TD CLASS="quote">I've owned a 4 Puck, 6 Puck, 6 Puck w/ Spring....
I love the 6 Puck ACT over the 4 Puck Version.</TD></TR></TABLE>why?
Old 11-16-2005, 07:14 PM
would it eat up my flywheel?
Old 11-16-2005, 08:30 PM
tegasaurus's Avatar
Default Re: (out of order)
my 6 puck ACT ate through the PP and flywheel within about 8000 miles. well, the chatter that was experienced wit hthe pucked clutch, i elimited by revving and slipping it higher... apparently that'll wear out a pucked clutch way before any organic.
so if you get it, prepare to have some "not smooth" driving or else it'll rip through your flywheel fast. and since you have a lightweight flywheel, im sure it'll be even more rough.
i suggest getting an act XTSS. bet clutch, and i'll never run anythign else in any honda i own.
Old 11-17-2005, 01:45 PM
Mohsin's Avatar
Default Re: (tegasaurus)
what flywheel would you recommend? Stock?
Old 11-25-2005, 04:04 PM
oh serious.. hm i thought about both 4 or 6 an decided not to get Neither 1 an instead got a Exedy twin plate/ thanx for all the info GUys.
here go some pics of the clutch.
Old 11-26-2005, 04:05 PM
tegasaurus's Avatar
unless you're making atleast 350ft/lb at the flywheel something like that is overkill. and im assuming you're running a turbo setup or you're making a dedicated drag car and looking for long term reliability.
for this guy, stay away frlom pucks.
Old 11-26-2005, 04:07 PM
Mohsin's Avatar
im debating to either go with exedy stage 2 or action 1MS. Im currently using a exedy stage 1 organic and love it.
Old 11-26-2005, 06:47 PM
PreIudeSI's Avatar
Location: California ... Beauuutiful, so cal, pwnited States
Default Re: (Mohsin)
tell us more about your setup. if you plan on just dragging this car or only driving it on the weekends and putting about 200-250 ftlb of torque to the ground, go for the 4 or 6 puck, they're cheap and hold a lot of tq. But if this is your daily driver stay the hell away from any puck type clutch and spend the extra 50 bucks on a sprung organic disc. get an act hdss or xtss some other type of sprung disc, your wheels will be hoppin over the ground with a puck type clutch; they're just not ideal for the daily driven street.
Old 11-26-2005, 08:23 PM
RedEj8's Avatar
Damn..Nice clutch! How much did that run u if u dont mind me asking?
Old 11-26-2005, 10:34 PM
Default Re: (PreIudeSI)
damn.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreIudeSI &raquo;</TD></TR><TR><TD CLASS="quote">tell us more about your setup. if you plan on just dragging this car or only driving it on the weekends and putting about 200-250 ftlb of torque to the ground, go for the 4 or 6 puck, they're cheap and hold a lot of tq. But if this is your daily driver stay the hell away from any puck type clutch and spend the extra 50 bucks on a sprung organic disc. get an act hdss or xtss some other type of sprung disc, your wheels will be hoppin over the ground with a puck type clutch; they're just not ideal for the daily driven street.</TD></TR></TABLE>
for dragg only. *weekends* my set up is a fully built gsr Sleeved 85 8:4:1 comp Full race turbo set up sc61 ramhorn mani 3" dp mandrel bend Pipes Gude Head . list goes on..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reddohcvtec &raquo;</TD></TR><TR><TD CLASS="quote">Damn..Nice clutch! How much did that run u if u dont mind me asking?</TD></TR></TABLE>
thanx it was pretty pricey the clutch i got it for 1200$
Old 11-27-2005, 12:10 PM
RedEj8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by out of order &raquo;</TD></TR><TR><TD CLASS="quote">thanx it was pretty pricey the clutch i got it for 1200$ </TD></TR></TABLE>
Nice! not too bad, hopefully it will last u a while
Old 11-27-2005, 01:06 PM
yeah hopefully/&gt;
MadSuRfEr
07-28-2006 04:14 AM
ernald711
10-02-2005 10:40 AM
EMJAY
07-15-2005 06:54 PM
jeremy.
10
10-29-2003 11:24 AM
Nate B
10-01-2002 01:08 PM
Quick Reply: act 4puck ?? bad or good?
