clutch squeels during engagement??
Old Nov 3, 2005 | 07:35 AM
mr_magoo's Avatar
Default clutch squeels during engagement??
i'm not sure if this could be my throwout bearing or if my flywheel needs to be resurfaced...when i put it in gear it jest makes this god ofal squeeling noise..act six puck unsprung hub with heavyduty pressure plate...flywheel was turned down to save weight but never resurfaced i don't think...any ideas
Old Nov 3, 2005 | 07:37 AM
snatch's Avatar
Default Re: clutch squeels during engagement?? (mr_magoo)
When you say
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_magoo &raquo;</TD></TR><TR><TD CLASS="quote">when i put it in gear it jest makes this god ofal squeeling noise</TD></TR></TABLE>
do you mean actually placing the shifter into gear, or when you start to take off? Mine did the same thing when I would let out on the clutch and start to take off. Twas the flywheel needing to be resurfaced. Fixed the problem and hasn't done it in 10,000 miles.
Old Nov 3, 2005 | 08:50 AM
shamoo's Avatar
Will you make something up for me please?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_magoo &raquo;</TD></TR><TR><TD CLASS="quote">act six puck unsprung hub with heavyduty pressure </TD></TR></TABLE>
That's the culprit right there. Pucked metallic clutches will ALWAYS squeal upon engagement. I had the 4 puck with the same pressure plate and had the same thing. It's just something we have to deal with.
SIDEXIT
14
Oct 13, 2008 12:55 PM
midnitesol
Sep 30, 2006 12:18 PM
h22silvia
Aug 18, 2006 08:23 PM
migs
Jan 13, 2006 04:09 PM
HS2G
Aug 22, 2004 07:34 AM
