gsr delsol clutch problems!!!
just installed new clutch kinda makes whistling noise but stops when you.put a little pressure on the clutch pedal. Also its hard to get into gear! please help!
Re: gsr delsol clutch problems!!! (midnitesol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by midnitesol »</TD></TR><TR><TD CLASS="quote">just installed new clutch kinda makes whistling noise but stops when you.put a little pressure on the clutch pedal. Also its hard to get into gear! please help! </TD></TR></TABLE>
did you only changed the clutch?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by midnitesol »</TD></TR><TR><TD CLASS="quote">no i changed the clutch and the flywheel.</TD></TR></TABLE>
might be the bearing that sits in the flywheel. when you're going to do a job like this you always want to change the clutch, resurface the flywheel (if needed), replace the pilot bearing. and if anyone knows what else i'm missing please post up.
Re: gsr delsol clutch problems!!! (philosofy1)
i bought a clutch kit thatcame with new pilot bearing, throwout bearing and alignment tool and it was a new flywheel. could it be that the pressure plate is to tight? thanks for your help!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by midnitesol »</TD></TR><TR><TD CLASS="quote">i bought a clutch kit thatcame with new pilot bearing, throwout bearing and alignment tool and it was a new flywheel. could it be that the pressure plate is to tight? thanks for your help!</TD></TR></TABLE>
what did you torque the bolts at? you do have a torque wrench, right?
actually no i know i should have used one but it was broken i used air tools would that be the cause of the problem?
i think it might be that the pressure plate is on to tight or from wat ive read i think it could be the throwout bearing? any one ever had this happen before?
an2ny888
Transmission & Drivetrain
09-07-2010 08:58 PM
