help with turbo install.
ok so i installed my turbo kit and now my car has no power and it sounds like an old rx7.
my setup:
B18B
srp pistons 9:1
eagle rods
port & pol head
gard block
fuel pump
RC 370cc
Chipped ECU
Garrett t3/t4 TB0356 turbo
greddy IC
XS turbo manifold
turboxs Blow Off Valve Type H
skunk 2 cam gears
my setup:
B18B
srp pistons 9:1
eagle rods
port & pol head
gard block
fuel pump
RC 370cc
Chipped ECU
greddy IC
XS turbo manifold
skunk 2 cam gears
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bartman201 »</TD></TR><TR><TD CLASS="quote">ok so i installed my turbo kit and now my car has no power and it sounds like an old rx7.
my setup:
B18B
srp pistons 9:1
eagle rods
port & pol head
gard block
fuel pump
RC 370cc
Chipped ECU
greddy IC
XS turbo manifold
skunk 2 cam gears
what chip is in it? was it a boost chip or just some run of the mill performance chip? if it is idling like **** and running like ****, i think a compression and leakage test is in order.
my setup:
B18B
srp pistons 9:1
eagle rods
port & pol head
gard block
fuel pump
RC 370cc
Chipped ECU
greddy IC
XS turbo manifold
skunk 2 cam gears
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">
what chip is in it? was it a boost chip or just some run of the mill performance chip? if it is idling like **** and running like ****, i think a compression and leakage test is in order.</TD></TR></TABLE>
it idles ok. what will happen if it leaks air thru the bov. also i don't see the internal wastegate moving when i give it gas or the bov realeasing pressure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">the wastegate will only move under boost, and it is possible you dont have the b.o.v. hooked up to manifold vacuum.</TD></TR></TABLE>
i T'd off the brake master line
i T'd off the brake master line</TD></TR></TABLE>
before or after the check valve?
before or after the check valve?</TD></TR></TABLE>
mani ________T________check_______brake master cylinder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bartman201 »</TD></TR><TR><TD CLASS="quote">mani ________T________check_______brake master cylinder</TD></TR></TABLE>
What kind of chip did you use? If you're using a chip with a map for different size injectors, or not made for a boosted car, it's going to run like crap.
Just curious, how was it running with one injector out and how did you figure it was the injector? did it like hesitate when you went on the throttle?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTcivicHB »</TD></TR><TR><TD CLASS="quote">Just curious, how was it running with one injector out and how did you figure it was the injector? did it like hesitate when you went on the throttle?
when i step on the car it was not responding right. my friend unplug one of the spark plug wires and nothing happen, he check the the injectors and the pin of one of them was sideways.
but now my car is only boosting like 2psi. someone told me to get a manual boost controller cause the factory setting for the internal wastegate wont let it boost more than 2-5 psi. is this true?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AbitAvenger »</TD></TR><TR><TD CLASS="quote">what turbo do you have?</TD></TR></TABLE>
garrett t3/t4
garrett t3/t4
You can't turn the boost down more than the internal wastegate, you can only turn it up, and I don't know of any T3/T4 turbos that have a 2 lb internal wastegate so I would say look for boost leaks? Does it feel like your only getting 2lbs of boost or does it feel like its boosting correct cause there could be a boost leak in your line to the gauge, just a thought.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo_b16_ex »</TD></TR><TR><TD CLASS="quote">your catalyic converter is clogged of you got boost leak. try running it in open downpipe and see if it spools</TD></TR></TABLE>
i have an open downpipe right now. can't boost over 5-6 psi
