NGK Iridium Plugs. No Gap=Ok?
Old Oct 30, 2005 | 11:14 PM
peacexisxfree's Avatar
Default NGK Iridium Plugs. No Gap=Ok?
so, youre not supposed to gap ngk's iridium plugs due to the extremely fine centre electrode.
im running a gsr with itr pistons and itr camshafts so im running around a 11:3 compression ratio.
would it be better just to go with ngk's platinum plug so i can gap them correctly, or should it not make a big enough difference?
Old Oct 30, 2005 | 11:38 PM
_gurusan_'s Avatar
Default Re: NGK Iridium Plugs. No Gap=Ok? (peacexisxfree)
I would just get NGK V-Power. They are great plugs, and very cheap.
Old Oct 30, 2005 | 11:39 PM
_gurusan_'s Avatar
Default Re: NGK Iridium Plugs. No Gap=Ok? (_gurusan_)
BTW platinum sucks IMO.
it doesn't conduct as well as copper OR iridium, it just lasts longer.
Old Oct 31, 2005 | 12:18 AM
IT'S ME DAVID's Avatar
NooB
just go with the ngks
Old Oct 31, 2005 | 12:49 AM
Default Re: NGK Iridium Plugs. No Gap=Ok? (K SERIES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K SERIES &raquo;</TD></TR><TR><TD CLASS="quote">just go with the ngks </TD></TR></TABLE>
I always was going NGK. I am just debating whether or not to go with the iridiums or not, since you cant gap them.
Old Oct 31, 2005 | 06:22 AM
TeamNextGenChris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peacexisxfree &raquo;</TD></TR><TR><TD CLASS="quote">
I always was going NGK. I am just debating whether or not to go with the iridiums or not, since you cant gap them.</TD></TR></TABLE>
as said above,the Iridium/Platinums only offer a longevity advantage,not any performance advantage.
you could buy several sets of the standard plugs for the price of one set of them,so money wise there's really not much difference.
i'd go with the standards since it will allow you to play with the gap.
Chris
Old Oct 31, 2005 | 06:31 AM
splitime's Avatar
Default Re: NGK Iridium Plugs. No Gap=Ok? (TeamNextGenChris)
BKR7E-11s... stock gap/plug for ITR. I run them ungapped on 11:1 motor with 0 issues. And they are more than cheap enough to replace yearly... platinum is for the people that just like spending more money than they need to. The cost vs efficiency ratio is better on coppers.
Old Oct 31, 2005 | 07:13 AM
rk4g63's Avatar
Run copper plugs
OneCrzySetup
Nov 17, 2006 11:53 AM
Phatch99
Sep 8, 2005 12:39 PM
2kstreetcivic
Mar 31, 2005 02:18 PM
LSVTEC 91 Civic
May 16, 2004 04:24 PM
rice a roni
27
Dec 7, 2003 01:08 PM
