SPARK PLUGS
Re: (stripes777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stripes777 »</TD></TR><TR><TD CLASS="quote">ngk homie, cant beat 2 bucks a pop</TD></TR></TABLE>
no doubt!!!
no doubt!!!
I have tried many Tyoes of spark plugs and i have noticed the Bosch plugs are the first to foul out. Ngk's Are great and I still run them in my car today i have even used old plugs and they have still worked for me. Lates
Re: (stripes777)
Re: (HATCHingMN)
Ngk's , I did happen to come across this though.
Blue line = Bosch #4227 Spark plugs
Red line = NGK V-Power Spark plugs
This motor is a single cam, all motor D16! And the customer won 1st place at the Battle of the Imports in his bracket!! Congratulations Will!
Anyway, Will, you owe me a set of Bosch plugs! Will didn't think in a million years that the Bosch would make power...then I put them in and changed his mind. We love changing peoples minds!
Jeff
That was takin from importreview.com
Jeff
Re: (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx »</TD></TR><TR><TD CLASS="quote">Ngk's , I did happen to come across this though.
Jeff
That was takin from importreview.com</TD></TR></TABLE>
Is that with 2 new sets of plugs, or changing from a worn out set of NGK to a new set of Bosch???
Jeff
Re: (EG2 SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2 SiR »</TD></TR><TR><TD CLASS="quote">
Is that with 2 new sets of plugs, or changing from a worn out set of NGK to a new set of Bosch???</TD></TR></TABLE>
I am guessing its 2 brand new sets.
Re: SPARK PLUGS (Eyewitness)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eyewitness »</TD></TR><TR><TD CLASS="quote">I do not recommend platinum plugs of any kind in a honda. </TD></TR></TABLE>
Any specific reason as to why?
Re: SPARK PLUGS (EG2 SiR)
Any specific reason as to why?</TD></TR></TABLE>
Yes. Platinum plugs are long life plugs. Often they are labeled "high performance" and so on. The only plug i would use besides copper is iridium. Iridium unlike platinum is a better conducter by far and worth the value. Its good to change your plugs at least every 15K anyways. Im tired so thats all the detail i can write...
Yes. Platinum plugs are long life plugs. Often they are labeled "high performance" and so on. The only plug i would use besides copper is iridium. Iridium unlike platinum is a better conducter by far and worth the value. Its good to change your plugs at least every 15K anyways. Im tired so thats all the detail i can write...</TD></TR></TABLE>
cool... I got confused for a second. . . I was thinking Iridium, cause that is what I am running and I like them.... But isn't the factory specified part for the Vtec Del Sol and Civic Si (B16) an NGK platinum plug?
cool... I got confused for a second. . . I was thinking Iridium, cause that is what I am running and I like them.... But isn't the factory specified part for the Vtec Del Sol and Civic Si (B16) an NGK platinum plug?</TD></TR></TABLE>
No. Its copper. NGK BK6RE-11 is USDM models. JDM came with BK7RE-11. And i believe the iridiums are BK6RE-N11.
New User
alittle note on those $bling$ plugs and dyno numbers. i bet those company compares worn plugs with
their new ****. of course you'll get a gain in power when you test old worn plugs against new ones.
go for the $2 a pop ngk v power. i jus change mine every 20K
