vtech problems
Old Oct 30, 2005 | 05:22 PM
jeys_si's Avatar
Default vtech problems
vtech is not kicking in. What could be the prob?
Old Oct 30, 2005 | 05:23 PM
Dragline's Avatar
Default Re: vtech problems (jeys_si)
Do you have a cel ?
Old Oct 30, 2005 | 05:26 PM
808_si's Avatar
check the oil?
Old Oct 30, 2005 | 05:34 PM
m00nr0ck Si's Avatar
vtec, anyways , you have to be more specific than that, what motor ,what ecu, hell what car, did you just do a swap ? vtec will engage if several factors exist, oil press. , temp, throttle position, rpm, . give us some more info on the car....
Old Oct 30, 2005 | 06:49 PM
kid-crx's Avatar
Default Re: vtech problems (dorkoftheyear)
please dont tell us u have a stock ls or something.....not all honda/acura engines have VTEC
Old Oct 30, 2005 | 06:55 PM
soslodelsol's Avatar
everything...
check for codes. then actually put a vtec motor in there.
Old Oct 30, 2005 | 08:45 PM
vc's Avatar
vc
first what kind of engine do you have?? and how do you know vtec isn't kicking in??
https://honda-tech.com/zerothread?id=1412978
u don't really feel a "kick" when vtec hits.. its like a smooth transition
Old Oct 31, 2005 | 04:32 AM
dewoine's Avatar
Default Re: (Bond)
the vtec jokes are so gay and immature
anyways do you have a cel ?
Old Oct 31, 2005 | 06:15 AM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: (dewoine)
dial 9-1-1
Old Oct 31, 2005 | 06:24 AM
chinkest_raver's Avatar
Default Re: (BrokeAssPinoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssPinoy &raquo;</TD></TR><TR><TD CLASS="quote">dial 9-1-1</TD></TR></TABLE>
remember to tell them some is trying to jack you <U>vtec</U>...then tellem you need help soon or its gonna die...
j/k, try to clean out your vtec solenoid (3 screws, and 2 plugs, easy DIY!) Once off wipe everything down and clean out the little mesh filter. I switched mine with a newer, cleaner soleniod and it works alot better. Kicks in just alittle it harder, hence I only have an EJ8. But I can sell you mine for cheap, dealer goes for $200+.
Old Oct 31, 2005 | 11:11 AM
jeys_si's Avatar
Man how did you know i had an ls... do you know what my problem might be? j/k. Im not that dumb i have a 99 civic si
Old Oct 31, 2005 | 11:25 AM
nighttrain33's Avatar
Default Re: (jeys_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragline &raquo;</TD></TR><TR><TD CLASS="quote">Do you have a cel ?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808_si &raquo;</TD></TR><TR><TD CLASS="quote">check the oil? </TD></TR></TABLE>
The oil needs to be at a certain level for vtec to work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dorkoftheyear &raquo;</TD></TR><TR><TD CLASS="quote">vtec will engage if several factors exist, oil press. , temp, throttle position, rpm, .</TD></TR></TABLE>
Does it not kick in at all, or is it kind of in and out?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vc &raquo;</TD></TR><TR><TD CLASS="quote">u don't really feel a "kick" when vtec hits.. its like a smooth transition</TD></TR></TABLE>
He should feel a difference when vtec hits. I certainly do, but many times d-series don't "kick" as hard.
-Shane
Old Oct 31, 2005 | 11:32 AM
f1z1c's Avatar
Its because you dont have Vtech Nitro :
http://www.vtechkids.com/produ...d=291
Your car's fuzzy logic computer kicks in vtec based on rpm and gear. It could be electrical or mechanical, you should go thru the factory diagnostic in the helms.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeys_si &raquo;</TD></TR><TR><TD CLASS="quote">vtech is not kicking in. What could be the prob?</TD></TR></TABLE>
breanna*
12
Aug 2, 2006 09:29 AM
J's GS-R
Feb 21, 2006 09:13 PM
b16mike
May 13, 2005 09:51 PM
Ch3mik
20
Mar 30, 2005 11:56 PM
swappedcivic
Dec 14, 2004 08:30 AM
