Log manifold/external wastegate
Old Oct 27, 2005 | 09:55 AM
boostdummy's Avatar
Default Log manifold/external wastegate
Just wondering what your guys think about this.
My current turbo setup is
Log Style Manifold
T3 Super 60(.48/.60) /interal wastegate(6psi)
TurboXS HP boost controller
2.5" downpipe Manderal Bends/2.5" crushed bends exhaust
I would like to be able to hold 18-20 psi.
With my current setup the car will boost up to 20 psi but falls right back to 15 psi. Would adding a external wastegate allow me to hold more boost to redline? With a Full 3" downpipe/exhaust manderal bends
I would be switching to this manifold
Engine is 2.0L and revs to 6800 rpms.
Thanks.
Old Oct 27, 2005 | 09:57 AM
stockredej1's Avatar
Default Re: Log manifold/external wastegate (boostdummy)
the 3'' will help hold boost higher up but you have to remember your running s t3 on a 2.0, its gonna choke up top.
Old Oct 27, 2005 | 10:16 AM
onemanlan's Avatar
As said, you'll choke up top. You'll also have to make your internal WG shut.
Old Oct 27, 2005 | 10:18 AM
null.'s Avatar
Default Re: (onemanlan)
IMO i think you should get a bigger turbo. you'll get full boost by 2k with that turbo though haha
Old Oct 27, 2005 | 11:11 AM
nfn15037's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostdummy &raquo;</TD></TR><TR><TD CLASS="quote">
With my current setup the car will boost up to 20 psi but falls right back to 15 psi.</TD></TR></TABLE>
Probably the internal wastegate being blown open by exhaust manifold pressure.
Old Oct 27, 2005 | 11:57 AM
boostdummy's Avatar
Default Re: Log manifold/external wastegate (nfn15037)
Thanks for the comments.
I am shooting for 275-300 WHP. I am cuurently @249 WHP with 15 psi of boost. I was hoping to be able to get 18-20 psi out this turbo and hopefully get me up the range I am shooting for.
Any suggestions on turbo that wil spool super fast liek what I Have now and still be able to get me 300?
Or Is it the internal wastegate??. The internal setup I Have just bolts on so i don't have to worry about shutting the flapper door.
Thanks.
Old Oct 27, 2005 | 12:10 PM
nfn15037's Avatar
I bet if you got a stiffer wastegate actuator you could hold 18+ easily. An external would be ideal, but inernal should work OK with a good actuator and adequately sized flapper and port.
Old Oct 27, 2005 | 12:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">
Probably the internal wastegate being blown open by exhaust manifold pressure.</TD></TR></TABLE>
Or the turbo is falling out of its range, a 2.0L motor is gonna choke the **** out of that turbo at Higher RPM's
Smokinsax's Avatar
The Boot
Thanks.</TD></TR></TABLE>
what kind of engine do you have. I bet you could reach your HP goals a little easier if you rev'd higher also.
Old Oct 27, 2005 | 12:44 PM
nfn15037's Avatar
Default Re: Log manifold/external wastegate (stockredej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockredej1 &raquo;</TD></TR><TR><TD CLASS="quote">Or the turbo is falling out of its range, a 2.0L motor is gonna choke the **** out of that turbo at Higher RPM's</TD></TR></TABLE>
True, a .63 exhaust housing and wheel would do well on that motor
Old Oct 27, 2005 | 02:16 PM
boostdummy's Avatar
this setup is not on a Honda Motor
So 6800 RPMS is the highest it revs.
So you guys think the .48 is to small?
With the short rpms I need something that wont be to laggy thats why I went with the .48 instead of the .63
Old Oct 27, 2005 | 05:20 PM
boostdummy's Avatar
Any more thoughts?
Old Oct 28, 2005 | 04:17 AM
boostdummy's Avatar
For the ppl who think the turbo is running out of steam
WHat turbo do you recond mend that will SPOOL very fast Because I am only reving to 6800 RPMS. Remember I am looking for 300WHP range
Modified by boostdummy at 8:09 AM 10/28/2005
Old Oct 28, 2005 | 06:03 PM
boostdummy's Avatar
bump
Old Oct 28, 2005 | 08:37 PM
a1320addict's Avatar
if you wanna hit 300....gt28rs....if you want to have room to make big numbers gt3071
karmadhi
Oct 1, 2011 04:12 PM
cslegacy
Jul 21, 2008 11:59 AM
007EG
Dec 14, 2007 04:27 PM
motormike40
Sep 4, 2006 06:11 PM
jdmfr3ak
Aug 11, 2006 05:05 AM
