Could this be a ground issue?
Anytime I have moderate wheel hop (for instance when I grab second gear), I get a check engine light. It turns out to be like 5 codes including TPS, Fuel Supply, Map, IAC, and Coolant temp sensor. What could cause this? During no other time will these codes come on. Its a B18A in a 91 CRX. All sensors appear to be pluged in tightly and correctly.
Could be I suppose. Try cleaning or replacing the ground from valve cover to the chassis, and especially the one from tranny to chassis. See if that helps. Should be a 10 minute job, and cheap/free to do. With that old of a car, it certainly wouldn't hurt anything to spend 10 mintues on doing that.
Jfrazer22
Jan 13, 2019 04:17 PM
civicef990
Nov 25, 2011 06:53 AM
