Virginia Emissions Inspection... how can I pass?? HELP!
Old Oct 26, 2005 | 08:30 AM
TiredToyotaDriver
Guest
Posts: n/a
Default Virginia Emissions Inspection... how can I pass?? HELP!
whats up guys... I'm trying to buy this car, but I'm scared that I wont be able to get tags for it... As some of you may or may not know, VA changed all the emissions inspections around as of August 2005... All 98+(obd2) cars must pass emissions through a laptop... the days of the little exhaust probe are gone...
Heres my problem... This car I want is an 01 lsvtec turbo... The ECU is the stock obd2, but it is wired with an obd1 harness to allow the use of Hondata S200b... My dads been in the biz for a while, and he says this will NOT pass emissions, therefore I will not be able to get plates...Several other people have also told me that it will not pass emissions unless I know someone who will pass it for me... anyone have any advice for me?? anyone who can pass it?? I know I cant be the first to have this problem... help!!
Old Oct 26, 2005 | 09:22 AM
drdisco69's Avatar
Default Re: Virginia Emissions Inspection... how can I pass?? HELP! (TiredToyotaDriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TiredToyotaDriver &raquo;</TD></TR><TR><TD CLASS="quote">The ECU is the stock obd2, but it is wired with an obd1 harness to allow the use of Hondata S200b</TD></TR></TABLE>
So then it's not the stock OBD2 ecu... You're right though, you can't plug up to it and do the inspection, because it's not an OBD2 ecu. There is always the option of putting an OBD2 ecu in the car temporarily, but you'd still need to drive it around for a bit to set the readiness codes. Other than that, you're going to have to cheat.
Old Oct 26, 2005 | 09:38 AM
TiredToyotaDriver
Guest
Posts: n/a
Default Re: Virginia Emissions Inspection... how can I pass?? HELP! (drdisco69)
to be honest, im not exactly sure what ecu the car has...
This was the seller's response when I asked him if the car would pass inspection, and which ECU it has...
(1:48 AM 10/26/2005) Mr.DC2TurBo: The car is obd2 but I have the obd1 harness wired to it. It will not pass emission unless you know someone, it's turbo/pnp/ls vtec so i doubt it.
from what I've been told, this is impossible... is it possible to have an obd2 ecu wired with an obd1 harness??
Old Oct 26, 2005 | 09:39 AM
TiredToyotaDriver
Guest
Posts: n/a
also, the car is turbo with hondata... so I wouldnt be able to just slap a different ECU in it...
Old Oct 26, 2005 | 09:47 AM
drdisco69's Avatar
The deal is the car is OBD2, of course. But to run the OBD1 ecu, you use an adapter harness that converts the OBD2 plugs to the OBD1 plugs into the ecu. To run hondata S200b, you need OBD1.
Old Oct 26, 2005 | 09:52 AM
TiredToyotaDriver
Guest
Posts: n/a
so which ECU must this car have, knowing that it uses hondata s200.... is it obd2 or obd1 ecu??
Old Oct 26, 2005 | 09:58 AM
drdisco69's Avatar
OBD1, probably a P28.
Old Oct 26, 2005 | 10:47 AM
TiredToyotaDriver
Guest
Posts: n/a
he swears its an obd2 ECU with an obd1 harness wired to it... im confused
Old Oct 26, 2005 | 11:57 AM
drdisco69's Avatar
It's not, but there's an easy way to find out. Just pull it out and take a look at the sticker on it.
Old Oct 26, 2005 | 06:38 PM
boosted k20's Avatar
if the car is turbocharged then most likely it has bigger injectors. to pass, remove the "OBD1" ecu and put in the stock OBD2 ecu and install stock injectors. drive around with it for a few miles but drive easy, dont hit boost or else u might blow up on the stock injectors. also u must make sure u have NO CEL. as long as u have no CEL with the OBD2 ecu then u should pass.
Old Oct 27, 2005 | 07:58 AM
TiredToyotaDriver
Guest
Posts: n/a
Default Re: Virginia Emissions Inspection... how can I pass?? HELP! (boosted k20)
I dont like the idea of yanking the ECU and injectors... I wouldnt trust it being that this car is very heavily modded... ill have to figure something out
Old Oct 27, 2005 | 08:10 AM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TiredToyotaDriver &raquo;</TD></TR><TR><TD CLASS="quote">I dont like the idea of yanking the ECU and injectors... I wouldnt trust it being that this car is very heavily modded... ill have to figure something out</TD></TR></TABLE>
Yeah, trying to set readiness codes on a stock system with all that is throwing too much unknown stuff into the mix. If you had a wideband, it would be a little better, because at least then you would know why it blew up. But just driving around going "I hope it works" is too great a risk.
Old Oct 27, 2005 | 08:49 AM
Hecdosage's Avatar
You have to learn or pay someone to show you how to trick the system. And most likely you have An obdII to obdI harness so that you can use a OBD1 ECU, that way you can use your Stock engine harness.
You have very few options. But what I would do is like someone mentioned but a little different is get an obdII ECU for the car and depending on your injector size I would get some 310cc and hook the greddy blue box also you will need to lower the boost of course and put a catalytic converter.
Old Oct 27, 2005 | 09:25 AM
Default Re: Virginia Emissions Inspection... how can I pass?? HELP! (Hecdosage)
i dont knowy u peeps r so worried. if u put on the stock injectors and put in the stock OBD2 ecu (which will take all of 15 min's!!) and u drive the car under 3-4K rpms just to get it inspected, then theres nothing to worry about. u wont be hitting boost so the car will be safe. Just see if u can get ur hands on a wideband O2 to check to see if the car is running too lean under 4K and just bump the fuel pressure up.
Old Oct 27, 2005 | 10:20 AM
Hecdosage's Avatar
Thats the problem right there if you bump up the fuel you are burning more fuel and there goes your "emissions" test, he is trying to past inspection so he can't have to much fuel burning.
Old Oct 27, 2005 | 02:09 PM
but on the new OBD2 test they dont do the tailpipe emissions check. all they check is to make sure ur car is not throwing any CEL's. if the car was OBD1 it would be different
Old Oct 27, 2005 | 05:09 PM
TiredToyotaDriver
Guest
Posts: n/a
k20 is right... as of aug 05 they just hook up to your ECU...the car isnt even started! turn the key on, hook up the computer... I have an inspector that will hook me up, but I have to find a STOCK 01 integra LS...plug my VIN in the computer, plug the stock LS into the machine.... inspection passed : D
its gunna suck doing that every 2 years though... ugh commonwealth SUCKS
Old Oct 27, 2005 | 07:42 PM
ur lucky, i have to do it every year in NC. its gonna suck when i eventually go turbo
Old Oct 28, 2005 | 02:37 AM
TiredToyotaDriver
Guest
Posts: n/a
well in 2 more years I'll need to do it all over again... i wish there were an easier way...
Bonty
Aug 15, 2005 10:45 AM
EX-T
Nov 3, 2003 08:20 AM
enrique
Aug 29, 2003 07:24 AM
boostincoupe
Jul 8, 2003 02:28 AM
00 FBP ItR
Mar 3, 2003 12:41 AM
