Which is engines are better 2 swap 4 a 93 civic
Old Oct 25, 2005 | 10:04 PM
baller78c4life's Avatar
Default Which is engines are better 2 swap 4 a 93 civic
B16A,or B18C, orh22A, orB16B/b18C5,or B20Vtec.. WHich engine swap should i get 4 my 93 civic... I dont do which is good or which is not good...
Old Oct 25, 2005 | 10:11 PM
nocturnaldragon's Avatar
Default Re: Which is engines are better 2 swap 4 a 93 civic (baller78c4life)
I sagest searching before you just makes posts like this your going to save yourself a lot of headaches with people flaming you.
https://honda-tech.com/zerothread?id=878010
That was sticked to the top of the forum, consider this your warning on the search function. Welcome to Honda-Tech
Old Oct 25, 2005 | 10:21 PM
Default Re: Which is engines are better 2 swap 4 a 93 civic (nocturnaldragon)
so which swap would be best....
Old Oct 25, 2005 | 10:24 PM
That depends, what are you looking to do? Speed, torgue, boast, N/A, this is such a general question if anyone is going to answer they need a lot more info, I sagest looking at the link I sent you and weigh them against what you plane on doing with the car, and then if you have more of an idea we can help you more,Idealy you want to narrow it down on your own but if you get stuck between say 2 engines then we can help you a lot more easily then what your asking now
Old Oct 25, 2005 | 10:31 PM
ALright i found the 2 i like it is the B16B and the B18c5...
Old Oct 26, 2005 | 08:01 AM
How would it cost 2 swap... But my 93 civic is automatic rite now..Would it cost more then 10G's 2 swap the engine and everything..
Old Oct 26, 2005 | 08:06 AM
JRizEJ6's Avatar
no it wont cost more than 10g's for a manual swap and for the motor.
Old Oct 26, 2005 | 08:09 AM
littlegreenb18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baller78c4life &raquo;</TD></TR><TR><TD CLASS="quote">How would it cost 2 swap... But my 93 civic is automatic rite now..Would it cost more then 10G's 2 swap the engine and everything.. </TD></TR></TABLE>
yes it will cost about 10g's. i'll do it.
Old Oct 26, 2005 | 08:14 AM
Default Re: Which is engines are better 2 swap 4 a 93 civic (littlegreenb18)
ALright 1 of u guys say its gonna cost about 10G's and the other says that its not...
Old Oct 26, 2005 | 08:26 AM
Slow EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baller78c4life &raquo;</TD></TR><TR><TD CLASS="quote">ALright 1 of u guys say its gonna cost about 10G's and the other says that its not... </TD></TR></TABLE>
What you shoul be smart enough to learn from this thread is that you need to do the research about 1) what your goals for the car are 2) what engine would you like to use to accomplish those goals 3) after you have done 1 and 2 worry about getting the engine and putting/getting it put in.
There is no magic car and engine combination that will be the "best". Alot of it is personal preference and objectives for the car.
Old Oct 26, 2005 | 09:43 AM
92civichatch1's Avatar
Default Re: Which is engines are better 2 swap 4 a 93 civic (Slow EJ8)
for petes sake bro search before u make yourself look dumb. anyway a motor swap will never go over 10,000 dollars unless maybe your doin the K swap into hatch and even then 10 Gs is high. a b16 is easy to come by and b18c isnt to tough to come by either. it should be like 2000 roughly to do the swap....
to do the auto to manual swap u need...
1. motor and manual tranny
2. flywheel
3. clutch kit(clutch, pressure plate, throw out bearing, pilot bearing and alignment tool)
4. bolts for flywheel and pressure plate (8 flywheel and 6 presure plate)
5. Shift linkage (obviously Bseries shift linkage they all interchangeable)
6. need rear bracket for rear mount
7. engine mounts
8. ecu for manual trans (you probably wanna stay obd1 so get an obd1 ecu)
9. need different starter (manual trans starter)
10. make sure u have the a/c mount and the other trans mount
11. axels
12. engine hoist
Old Oct 26, 2005 | 09:45 AM
db8xc1x39
Guest
Posts: n/a
b18c5 def, nice
Old Oct 26, 2005 | 10:11 AM
rasinhell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">What you shoul be smart enough to learn from this thread is that you need to do the research about 1) what your goals for the car are 2) what engine would you like to use to accomplish those goals 3) after you have done 1 and 2 worry about getting the engine and putting/getting it put in.
There is no magic car and engine combination that will be the "best". Alot of it is personal preference and objectives for the car. </TD></TR></TABLE>
i agree
this post is dumb, but if ur really a baller 4 life then k20
Hoser
Jan 12, 2015 11:12 AM
mclark94
10
May 13, 2012 05:29 AM
ted
Dec 30, 2004 09:49 AM
chulopilong
Aug 14, 2003 04:59 AM
