flywheel noise
i recently put in a l.w flywheel in my car.since i put it in there has been a whine comming from it.sounds like a supercharger which is pretty cool but should it be making this noise.tourqed all bolts as specified etc
thanks.
thanks.
only whines when the clutch is out either under accel or decel.the engine is relatively new only 70k miles and previuos owner was an o.a.p until 68k miles,so i didnt see any reason why i should have to change the bearings.
Its just a good habit, if you have something torn down like that to replace wearable items like bearings. Just something Ive always done, not necessarily a "have to" thing.
As for the whine, did you relube the input shaft going back into the bearing? Did you accidently damage the bearing moving it from one flywheel to the other? Did you put tranny oil back in?
Dumb question I know, but it has to be asked.
