b series into 96 ek
are these the right part numbers and only mounts i will need to buy?
Rear Tranny mount from the 99-00 Si: 50827-S04-N10
Driver side mount bracket from the 99-00 Si: 11910-P30-000
just need to double check to make sure im getting the right parts.
You can use your stock motor mounts. The only thing that you need to change is the REAR crossmember mount. You'll need one from a 99-2000 Si.
JDM99DC2
Apr 12, 2005 06:15 PM
