NO Spark, New coil and ignitor....
Old Oct 21, 2005 | 08:39 AM
Blaze45's Avatar
Brrraaaap!
Default NO Spark, New coil and ignitor....
I was hitting about 5lbs in 5th @ about 2500rpm and suddenly the car just stops accelerating. I let off and then floor it again, POP!!! It backfires, this happend like 3 times so I stopped. I just bought a new ignitor about 3 months ago and I bought a new coil today and it still wont start. I know its getting fuel. When I had a friend turn it over I held the #1 plug wire next to a valvecover nut and I couldnt get any spark to arc when she turned it over... Im lost on what to look for next. I thought maybe wiring, but Ive sodered all my conncections. I did however find that the screw that holds the rotor on had worked itself out, so I screwed it back in... but Im lost where to look next....
thanks
Blaze
Old Oct 21, 2005 | 11:03 AM
EG1.8cT68's Avatar
Check your main relay. It may be powering the fuel pump but not the ECU
Old Oct 21, 2005 | 11:48 AM
gottagofaster's Avatar
Default Re: NO Spark, New coil and ignitor.... (Blaze45)
I'm having the exact same problem...no turbo on mine...but no spark to the plugs...if you have any luck please let me know and I'll do the same...
Old Oct 21, 2005 | 01:43 PM
Chiovnidca's Avatar
Default Re: (EG1.8cT68)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG1.8cT68 &raquo;</TD></TR><TR><TD CLASS="quote">Check your main relay. It may be powering the fuel pump but not the ECU</TD></TR></TABLE>
I dont beleive that's possible. Vice versa, yes.
Old Oct 21, 2005 | 01:44 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote"> When I had a friend turn it over I held the #1 plug wire next to a valvecover nut and I couldnt get any spark to arc when she turned it over... </TD></TR></TABLE>
Have you checked fuses? Busted t-belt?
Old Oct 21, 2005 | 05:15 PM
Blaze45's Avatar
Brrraaaap!
Default Re: NO Spark, New coil and ignitor.... (Chiovnidca)
OK heres the update- compession is good on all cyls, getting spark and fuel. I guess the only one left is timming... I made sure that it was on 2 times, Im done with it for tonight... All the fuses are good. I hate my car right now, I just want to hit 15lbs again...
Blaze
Old Oct 21, 2005 | 11:57 PM
I don't know what your setup is, but I fixed my problem today by removing my MSD and putting the stock ignition system back on. Then I also found a problem when I re-wired my VAFCII to my ECU, my RPM signal wire wasn't making good contact. I got that set in good and I'm running like a champ.
stevejames
Nov 24, 2016 01:23 PM
hey man
Dec 22, 2010 06:59 AM
pmey
May 26, 2009 01:11 PM
LagunaSecaEG
24
Mar 7, 2007 09:14 AM
masterp
Dec 5, 2006 02:26 PM
