Block Rebuild ?'s
Old Oct 21, 2005 | 06:51 AM
hondaluva's Avatar
Default Block Rebuild ?'s
So I pretty much killed the compression in my ls block and i've decided to rebuild the bottom end. I will be using .25 oversized jdm p30 pistons, ls rods (shootpeened?), acl bearing, arp rod bolts, and possibly get everything balanced and blueprinted. If i'm using a stock b16 head do i need bigger injectors or can i run the stock ones until i build the head. i'll be tuning will hondata s100
Old Oct 21, 2005 | 09:58 AM
hondaluva's Avatar
Default Re: Block Rebuild ?'s (hondaluva)
bump for some help
Old Oct 22, 2005 | 03:35 AM
2quikmotorwerks's Avatar
No, your stock injectors will be fine, if you were running an high c.r then yeah but your'll be allright, but if you have your heart set on getting some injectors just grab a set of 310's and a fpr and you'll be in the game this way you have more fuel incase you decide tou up your c.r in the future.
Old Oct 22, 2005 | 07:22 PM
hondaluva's Avatar
Default Re: Block Rebuild ?'s (2quikmotorwerks)
well i know the p30 pistons will put my c.r. around 11.3 so with that said stock injectors will be fine right? At least until i get a valvetrain package and a sets of cams.
Old Oct 23, 2005 | 07:42 PM
hondaluva's Avatar
bump
Chee_dog
Dec 17, 2008 06:17 AM
VTECdohcter
Jul 26, 2008 08:35 AM
Lordofdark176
Nov 21, 2007 08:42 PM
slambedcivic
Aug 8, 2006 07:48 AM
Topdawgg
Jan 30, 2006 06:33 PM
