how many turbo guys are running stock head gasket
Old Oct 18, 2005 | 09:27 PM
Hulk22's Avatar
Default how many turbo guys are running stock head gasket
im about to start my turbo project and i chose not to use the thicker head gasket to lower my comp. i have a stock block for now getting built for the winter. ive heard many stories what you can and can not do, but anything is possible with good tunning!
so i was wondering how many people are running on stock compression, what psi are you running on pump gas. and what are you running on race gas. i know you can run more boost on the lower compression but you also lose power . if you use a 2mm thicker gasket that will drop around 9 something somewhere around 30-40 pending mods, i know what my goals are and stock block wont cut it. but it will keep me happy for a few months. after talking to a few shops that done h22s they vary 430-465whp get better pistons and rod rings 480-500whp. dont hold me to this as i did not ask for dynos. i spent aleast 45-hr talking in person to these people and putting the facts together that suppoted each other. bottem line sleeve block lots of power! so if you our blocks can only handle so much lets say on the power side with deacent drive(keep in mind traction!) 350-380whp=420-456flywheel which is damn good. from what ive seen pep. that are running thinker hg on stock block are getiing 250-290 give or take for turbo and tuning at 8-9psi oh also take for us/jdm would be the higher numbers i have jdm. so if you keep stock comp your around 280-320 and better tork. =better hole shot faster spool! so i would like to know what psi your running and what kind of power your running. THANKS Ps sorry for it being so long did not want people yelling go search just whated to be detailed about why im asking.
Old Oct 18, 2005 | 09:36 PM
mgags7's Avatar
1) get out of here
2) there are turbo guys with turbo gaskets and turbo information in the turbo forum
3) punctuate that avalanche of bs
4) search you classic idiot style turbo *****
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hulk22 &raquo;</TD></TR><TR><TD CLASS="quote">tork</TD></TR></TABLE>
Old Oct 18, 2005 | 09:39 PM
Soda Popinski's Avatar
Default Re: (mgags7)
Well to answer your question, you can make awsome power, on race gas and and awsome tuner! High octane gas and like 15lbs is possible on stock bottom end. That right there depending on the turbo is 300-400whp.
Old Oct 18, 2005 | 09:50 PM
Jeffrey9's Avatar
Default Re: (Matador)
Did I catch a "tork" in there?
mgags7's Avatar
^^listen to this guy....he has his own personal account with mobil1 so he can keep his engine full weekly....
Old Oct 19, 2005 | 04:00 AM
Hulk22's Avatar
thanks
Old Oct 19, 2005 | 07:02 AM
The Phil's Avatar
Default Re: (Hulk22)
What the...
Old Oct 19, 2005 | 07:52 AM
PrecisionH23a's Avatar
Default Re: how many turbo guys are running stock head gasket (Hulk22)
stock is the way to go. i've put out right below 500 on my built h23a with stock HG.
Old Oct 19, 2005 | 08:07 AM
prelittlelude's Avatar
Default Re: how many turbo guys are running stock head gasket (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">stock is the way to go. i've put out right below 500 on my build h23a with stock HG.</TD></TR></TABLE>
ah mr 10k posts himself speaks the thruth, i am also on a stock head gasket.
Old Oct 19, 2005 | 12:12 PM
brandond's Avatar
B A N N E D
Default Re: how many turbo guys are running stock head gasket (prelittlelude)
very sweet!
Old Oct 19, 2005 | 03:46 PM
h22_crx's Avatar
Default Re: how many turbo guys are running stock head gasket (brandond)
i think steve oaks run's a stock head gasket
Old Oct 19, 2005 | 04:03 PM
h22 civic's Avatar
Default Re: how many turbo guys are running stock head gasket (h22_crx)
stock hea dgasket
Old Oct 19, 2005 | 07:30 PM
Broken Devil's Avatar
Default Re: how many turbo guys are running stock head gasket (h22 civic)
The book <U>Maximum Boost</U> says lower compression head gaskets are a bad idea.
Old Oct 19, 2005 | 08:13 PM
XES's Avatar
XES
Default Re: how many turbo guys are running stock head gasket (Broken Devil)
I've always been on stock headgaskets
Old Oct 20, 2005 | 07:16 AM
jdmturbosol's Avatar
Default Re: how many turbo guys are running stock head gasket (XES)
use stock man
Old Oct 21, 2005 | 10:47 PM
Hulk22's Avatar
Default Re: how many turbo guys are running stock head gasket (jdmturbosol)
thanks everybody it really boils down to haveing the right turbo for the job and good tunnig with a good top combo 350-390whp is within range. that should keep calm for a min. until the built bottom.
Old Oct 22, 2005 | 09:48 AM
LudeyKrus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Broken Devil &raquo;</TD></TR><TR><TD CLASS="quote">The book <U>Maximum Boost</U> says lower compression head gaskets are a bad idea.</TD></TR></TABLE>
All they do is add/subtract from the height of the block or head basically, playing with the cam timing. The proper way to mess with compression is to use higher/lower compression pistons in combination with the head of your choice.
Stock headgasket is the way to go.
Old Oct 22, 2005 | 12:39 PM
l2yanE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">1)4) search you classic idiot style turbo *****</TD></TR></TABLE>
ROFLMAO
i think ur gonna get a good idea what weak ringlands mean-
JDM_SOHC
Aug 10, 2007 04:09 PM
Hulk22
Oct 19, 2005 06:33 PM
B00ST2nR
Aug 25, 2004 08:46 AM
hybrid901
Honda S2000
Aug 11, 2004 10:53 AM
Cyber ITR
Jul 17, 2001 12:51 PM
