I am having problems setting up my EBC
Hey... first off this is not a popular EBC... it just hit the market it is in its testing phase right now....
basically you can go here to see it... http://forum.tullostech.com
anyways heres my problem...
i have it setup but it wont hold boost correctly...
on the high boost setting itll normally 7psi then jump quickly to about 12psi....
and on the low boost setting itll slowly gain boost and keep slowly gaining till 12+psi..
now i know you probably dont know what features are on the BC... basically
here is the tuning program that comes with the EBC...
http://www.tullostech.com/software/setuph11.exe
and heres the PDF Manual
http://www.tullostech.com/pdf/...5.zip
here are my settings
ok in the Boost tab i have boost unlocked so i can use the ***** on the unit to adjust low and high....***(MY ***** ARE SET AT 7psi low and 12psi HIGH)***
the gain is locked at 25
my overboost is at 13.5psi
ADVANCED CONFIG
IDLE PWM: 90
LOW PWM 75
Boost range (**** range) 6 to 13psi.
and i have the inverted PWM box checked (so i can run the top port setup on my wastegate)
now if someone could PLLLEASE check out the program and maybe play with it and read the manual... i know it probably is somewhat similar to the AVC-R or something... someones gotta have somethign for me to better my boost...
ADVANCED CONFIG
IDLE PWM: 90
LOW PWM 75
