I HAVE A BROKEN INSTRUMENT BULB...WHAT NOW
94 hatch cx
i have a broken instrument bulb in the center control panel where the temperature control/fan 1 2 3 4/ air vent control, etc. how do i go and removing this??
remove 4 screws from that ashtray console, then remove cd player, then there should be 3 screws holding that climate control (1 screw is in the middle back, 2 screws are in the front), unplug the harness, remove the wire that leads to the bottom of the glove box(fyi, it controls when you move it to hot or cold), and then pull it out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by resol »</TD></TR><TR><TD CLASS="quote">remove 4 screws from that ashtray console, then remove cd player, then there should be 3 screws holding that climate control (1 screw is in the middle back, 2 screws are in the front), unplug the harness, remove the wire that leads to the bottom of the glove box(fyi, it controls when you move it to hot or cold), and then pull it out</TD></TR></TABLE>
we need more people like this on honda-tech
thanks i'll give it a shot. by the way, my fan is not working, when i turn it to speed 1, 2, 3, or 4 it does nothing. i think the vent fan under my glove box is broken, or somthign might be wrong with it, i check fuse, none blown. any idea on what to do?
https://honda-tech.com/zerothread?id=661308
that has pictures, just scroll down past the cluster part and it will have step by step instructions for the climate control
I LUV MY EJ1
Oct 21, 2008 08:37 PM
ner0x
Jun 23, 2005 07:17 PM
