take a look --> am I missing anything???? 92 GSR ABS Question.
Old Oct 11, 2005 | 05:01 PM
92integraVTECgsr's Avatar
Default take a look --> am I missing anything???? 92 GSR ABS Question.
i have a 92 integra gsr with ABS.
Look where the pen is pointing, is there supposed to be a little ball in there? like the 2 beside it on the left? Right now there is nothing there. it looks like brake fluid drips out of there. But IT IS BARELY anything. I'm not loosing break fluid, but I'm wondering if anything is supposed to be there blocking air???
I do not know. If you guys with ABS could check yours and see if im missing something in that hole that would be great.
thanks.
Old Oct 11, 2005 | 05:33 PM
Default Re: take a look --> am I missing anything???? 92 GSR ABS Question. (92integraVTECgsr)
anyone?
Old Oct 11, 2005 | 06:02 PM
apok's Avatar
I'm not familliar with older ABS systems, since I own an Integra with the small ABS unit and not many older Integras get swaps done, but you could see if air is getting in by bleeding your brakes. If the fluid doesn't stream out after maybe one or two rounds, then you're getting air in the system.
Old Oct 11, 2005 | 06:40 PM
SwedBoy2999's Avatar
I'll look at my DB2 when i get home from work.
Old Oct 11, 2005 | 07:04 PM
Default Re: take a look --> am I missing anything???? 92 GSR ABS Question. (SwedBoy2999)
thanks.. well i just flushed and bleed the entire system a few weeks ago. They fell ok, but I was just wondering because of the very little fluid coming from the hole.
Old Oct 11, 2005 | 09:26 PM
bump
Old Oct 11, 2005 | 09:40 PM
watsvtecEK's Avatar
i like your pen
Old Oct 12, 2005 | 07:05 AM
Default Re: take a look --> am I missing anything???? 92 GSR ABS Question. (b18tegra)
haha thanks.
Old Oct 12, 2005 | 08:24 AM
Well from the looks of these pictures it seems there is a ball bearing in there.
Good Luck,
~Eric
Old Oct 12, 2005 | 09:17 AM
hmm.. i thought so.. didnt think there was supposed to be any fluid coming from that hole.
oh well.. when i get time, money and find a replace or way to fix it, I will.
Old Oct 12, 2005 | 09:47 AM
MAV3RiCK478's Avatar
wipe it dry and put some hondabond.
Old Oct 12, 2005 | 01:46 PM
Default Re: take a look --> am I missing anything???? 92 GSR ABS Question. (MAV3RiCK478)
maybe.. i wonder what the purpose of that ball is???
Old Oct 12, 2005 | 10:31 PM
GrayT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">maybe.. i wonder what the purpose of that ball is???</TD></TR></TABLE>
Another way to quickly bleed?
Old Oct 12, 2005 | 11:54 PM
blk_db2's Avatar
Default Re: take a look --> am I missing anything???? 92 GSR ABS Question. (GrayT)
How do you bleed it from there... I don't see any threads? I thought that you needed a special bleeder tool for ABS cause its under a lot more pressure than the regular master cyclinder...
Old Oct 13, 2005 | 06:44 AM
Default Re: take a look --> am I missing anything???? 92 GSR ABS Question. (blk_db2)
i think he was just joking.
Old Oct 13, 2005 | 09:06 AM
blk_db2's Avatar
Well you never know with people around here...
Anyways you should slam on your brakes hard and see how much fluid come out of that hole I still don't understand how that ball bearing came out
Old Oct 13, 2005 | 10:01 AM
GrayT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk_db2 &raquo;</TD></TR><TR><TD CLASS="quote">Well you never know with people around here...</TD></TR></TABLE>
Not just here... internet doesn't do a great of conveying emotions, more specifically sarcasm, too well.
lak8
May 2, 2008 02:40 PM
integ3
Dec 22, 2006 09:33 PM
jonzel
Aug 18, 2005 04:47 PM
lilcaliplayany
Apr 12, 2004 06:14 PM
bps2799
Jun 28, 2001 09:06 AM
