ABS modulator install...help
About to instal a new MC and a used ABS modulator. Is the ABS modulator as simple as it looks to install, just bolt the frame in and attatch the 6 brake lines? Is their any pre-bleeding liek with the MC that needs to be done. Anyone ever install one of these b4, any help would be great, thanks
you will have to bleed all the brakes after opening the system to air. I also believe you have to fill the MC up with fluid before you put it on so that less air will get in the system.
I understand the MC installation, i have done that b4, but the abs modulator is new to me, i guess i am mainly looking for any special installation steps for the Abs modulator
