Replaceing ABS modulator.
Old Dec 22, 2006 | 04:55 PM
integ3's Avatar
Default Replaceing ABS modulator.
Mine is bad on my '92 teg, so I got another one off of ebay. Has anyone ever replaced one of these? I looks like there are seven metal lines connected to it and one rubber hose.
-Is there a process to replaceing this thing?
-Do I just disconnect all of the lines, remove the unit, put in the new one, then reconnect all of the lines?
-Also, do I have to bleed the ABS system some how?
-Is the ABS system isolated from the brake system fluid? In another words will I have to bleed my brakes also.
Any advic eon this job would be great.
Thanks
Old Dec 22, 2006 | 05:39 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Yes you will have to bleed the ABS system, and you will also have to bleed the brakes. I don't know about the actual procedure of replacing the modulator and bleeding the ABS, it's in the Helm's manual somewhere.
Old Dec 22, 2006 | 09:33 PM
integ3's Avatar
Does anyone have a helms they can look at to see how I am suppose to bleed the ABS system?
AtoZ
Nov 28, 2009 09:59 AM
Kid1320
Jun 14, 2004 03:44 AM
joeseph
May 23, 2003 10:13 AM
4doorH22
Sep 22, 2001 07:48 PM
