Tachmeter is not working! But the MPH is.
Old Oct 11, 2005 | 12:18 PM
Tuan's Avatar
Default Tachmeter is not working! But the MPH is.
FIXED!!!
Modified by Tuan at 8:12 AM 1/25/2006
Old Oct 11, 2005 | 03:27 PM
tasco's Avatar
Default Re: Tachmeter is not working! But the MPH is. (Tuan)
hopefully someone has an answer because my tach is doing the same thing.
Old Oct 11, 2005 | 03:55 PM
kchungb17a's Avatar
Default Re: Tachmeter is not working! But the MPH is. (tasco)
This guy was missing a plug on his rear cluster:
https://honda-tech.com/zerothread?id=1392633
Did you get all your plugs back in place? I know you said you swapped the dash, so it could be lost in the lower dash area.
Old Oct 11, 2005 | 05:47 PM
95lstegman's Avatar
Default Re: Tachmeter is not working! But the MPH is. (kchungb17a)
or the VSS could be cut from the swap, or it may be inop. just a suggestion. VTEC won't kick in if it's inop (i believe), so if you're getting VTEC then the VSS is fine.
Old Oct 12, 2005 | 09:52 AM
Tuan's Avatar
Default Re: Tachmeter is not working! But the MPH is. (95lstegman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95lstegman &raquo;</TD></TR><TR><TD CLASS="quote">or the VSS could be cut from the swap, or it may be inop. just a suggestion. VTEC won't kick in if it's inop (i believe), so if you're getting VTEC then the VSS is fine.</TD></TR></TABLE>
Thanks, but i'm still hurting for an answer.
None of the wires are cut or spliced or etc.
Old Oct 12, 2005 | 09:57 AM
98 Spec R's Avatar
The tach signal comes from the blue wire on your distributor. Not the VSS sensor.
Old Oct 12, 2005 | 12:26 PM
95lstegman's Avatar
Default Re: Tachmeter is not working! But the MPH is. (98 Spec R)
oh crap i could have sworn i read it the other way around . . . speedo inop but tach operational. sorry.
Old Oct 12, 2005 | 01:19 PM
Tuan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95lstegman &raquo;</TD></TR><TR><TD CLASS="quote">oh crap i could have sworn i read it the other way around . . . speedo inop but tach operational. sorry.</TD></TR></TABLE>
My SPEEDO WORKS, but my Tach is NOT operational. You did read it correctly.
Old Oct 12, 2005 | 01:28 PM
95lstegman's Avatar
haha i'm sorry now i have you confused. inop=inoperative, not working. i thought your speedo wasn't working but your tacho was working.
Old Oct 12, 2005 | 01:45 PM
TurdBlown Teg's Avatar
just buy A HUGE tach and call it a day
Old Oct 12, 2005 | 03:22 PM
Tuan's Avatar
Default Re: (kevin716)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevin716 &raquo;</TD></TR><TR><TD CLASS="quote">just buy A HUGE tach and call it a day </TD></TR></TABLE>
HAHA...!
I wish i can but i need this car perfectly stock. Don't want any hassle from the SMOG GODS! Even i MAY install a 10" TACHOMETER!
Old Oct 12, 2005 | 03:30 PM
Kito96LS's Avatar
Default Re: (Tuan)
check ur distributor if the tach isn't workin then no signal is bein send to the tach..from the distributor...if u would have went wit an LS is would never happen!!!hahahahaa
Old Oct 12, 2005 | 04:28 PM
Tuan's Avatar
Default Re: (Kito96LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kito96LS &raquo;</TD></TR><TR><TD CLASS="quote">check ur distributor if the tach isn't workin then no signal is bein send to the tach..from the distributor...if u would have went wit an LS is would never happen!!!hahahahaa </TD></TR></TABLE>
That's a good start. I'm gonna check if the distributor is giving out a signal.
thanks!
Fighterinsnatch
12
Jan 17, 2008 01:40 PM
mtg4gen
May 13, 2007 06:14 AM
badbeast
Jul 16, 2006 09:45 PM
wrecks
16
Sep 2, 2005 05:59 AM
veilsides2000
Oct 18, 2004 07:38 AM
