H22 Type S A's and B's Pistons and Rings
Old Oct 10, 2005 | 05:05 PM
92hondalude's Avatar
Default H22 Type S A's and B's Pistons and Rings
Where can i find Type s pistons with rings for my h22a4 block.
I need 1 A (87.05mm) and 3 B's (87mm)
All the place i have called said that they only sell them in sets of four.
What do i do?
Modified by 92hondalude at 3:53 PM 10/11/2005
Old Oct 10, 2005 | 06:54 PM
jarel's Avatar
bore the 1 cylinder to match the 87.05 and just buy one set. Thas what i would do. Just curious, why is only one cylinder 87 and the rest 87.05?
Old Oct 11, 2005 | 03:48 AM
Default Re: (jarel)
thats just how the block came from honda
Old Oct 11, 2005 | 09:23 AM
thedread's Avatar
Default Re: H22 Type S A's and B's Pistons and Rings (92hondalude)
"Where can i find Type s pistons with rings for my h22a4 block.
I need 1 A (87mm) and 3 B's (87.05mm)
What do i do?"
The A piston is the larger diameter not the B. Buy a set of A and have the B cylinders honed to accept them.
Old Oct 11, 2005 | 11:47 PM
J-specCb4's Avatar
Default Re: H22 Type S A's and B's Pistons and Rings (thedread)
if u didnt already know which im pretty sure u did watch urself when honing an h block it a nickasil block.... and u need diamond coated stones to hone properly so the rings will take seat
Old Oct 12, 2005 | 09:56 AM
thedread's Avatar
Default Re: (92hondalude)
92hondalude, the dia of the H22 pistons are listed below:
Actual measurements in mm (source: Helm):
A = 86.990-87.003
B = 86.980-86.993
OS = 87.260
Old Oct 12, 2005 | 10:04 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: H22 Type S A's and B's Pistons and Rings (J-specCb4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J-specCb4 &raquo;</TD></TR><TR><TD CLASS="quote">if u didnt already know which im pretty sure u did watch urself when honing an h block it a nickasil block.... and u need diamond coated stones to hone properly so the rings will take seat</TD></TR></TABLE>
You sure about that? Im pretty sure thay are frm and require a special fine hone, yup , i was right please dont spread misinformation
SB618958 #18939
1990-2001 Prelude – Honing Fiber Reinforced Metal (FRM) cylinders 2000-01 S2000
All S2000 and 1990 and later VTEC and SI Preludes have Fiber-Reinforced Metal (FRM) cylinder liners. FRM honing is not required unless the cylinder has deep vertical scratches that run the length of the bore. Cylinders with light colored spots or flaking cannot be corrected by honing and must be replaced.
To hone FRM liners, perform the following:
· Use a rigid hone (not a ball hone) with GC-600-J or finer stones for nonferrous
metals. The honing pressure should be 200-300 kPa (2-3 kg-cm2, 29-43 psi).
· Use an oil type honing oil.
· Hone at 45-50 rpm to a 60 degree-crosshatch pattern.
· Do not stroke the hone more than 20 cycles.
· After honing, thoroughly clean the engine block of all metal particles by
washing with hot soapy water, then dry and oil them immediately. Never use
solvent; it will only redistribute the grit.
· Some light vertical scoring and scratching is acceptable if it isn’t deep enough
to catch your fingernail, and doesn’t run the full length of the bore. (rm,sn
Old Oct 14, 2005 | 12:25 AM
J-specCb4's Avatar
Default Re: H22 Type S A's and B's Pistons and Rings (PURPLETERROR aka BIGMATT)
i was simply stating that u needed a special hone that is all
drew1987
Apr 15, 2008 01:22 PM
charlee
Jan 26, 2008 12:02 PM
NoVALude
May 13, 2005 02:06 AM
Robban26
15
Jan 24, 2004 01:31 AM
1 2 NV
Oct 15, 2002 04:54 AM
