Disconnect fuel pump -- quick question.
Old Oct 10, 2005 | 08:53 AM
knoj's Avatar
Default Disconnect fuel pump -- quick question.
I am towing my car to have the Crank Shaft bolt removed for $30, but I already have the head removed. I need to leave the battery hooked up because I have no door handels, so that is not realy an option. If I turn on the ignition, the fuel pump will pump fuel out onto the ground (no head, nothing for the other end of the fuel line). I have my back seat removed, can I simply unplug the wire going into the aluminum guard? I need to stop the fuel from running, but the ignition must be on so the steering wheel will turn. Should I unplug the ECU instead?
Thanks for any information/suggestions you can provide.
Old Oct 10, 2005 | 08:59 AM
ssbpturbohatch's Avatar
Default Re: Disconnect fuel pump -- quick question. (knoj)
just unplug it at the pump, like you said
Old Oct 10, 2005 | 09:38 AM
suspendedHatch's Avatar
Default Re: Disconnect fuel pump -- quick question. (ssbpturbohatch)
Or just pull the fuse.
Old Oct 10, 2005 | 01:50 PM
knoj's Avatar
Default Re: Disconnect fuel pump -- quick question. (suspendedHatch)
Thank you! That was the obvious, but not so obvious answer. Worked well.
pappasmurf
Nov 11, 2024 07:43 AM
incognito E46
Feb 21, 2006 05:33 PM
Jamison
Jul 11, 2002 12:07 PM
T817
Mar 15, 2002 05:50 PM
