just bought a gsr motor couple questions`
bought a 99 gsr motor the motor sat in a wrecked car for 5 months non op
the motor wasnt started, ran or anything
swapped motor into 92 hatch is there anything we should look out for? like driving it easy for certain miles or anything?
if it was a wrecked car with any front end damage, I would have looked for any cracks or damage to anything you bought.. namely the motor and tranny.
If everything looks good, and seems to be retaining all your fluids you put in, pull your ecu fuse, and your spark plug wires off your plugs and turn the car over several times to build up oil pressure. Then put it back together and start it up. Id drive a lil easy to see if you hear anything odd in the motor or trans.. and if not, then just let er' rip.
Re: (EgSalad)
the car was rear ended and the motor is retaining fluuids and fired up first crank, but it was sitting for a little over 4 1/2 months...should i baby it or just let vtec roar?
Re: (beaneg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaneg6 »</TD></TR><TR><TD CLASS="quote">the car was rear ended and the motor is retaining fluuids and fired up first crank, but it was sitting for a little over 4 1/2 months...should i baby it or just let vtec roar?</TD></TR></TABLE>
just let vtec roar
just let vtec roar
Re: (beaneg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaneg6 »</TD></TR><TR><TD CLASS="quote">ok! im gettin mixed answers....
let vtec roar OR baby it for 500 miles?
and can someone explain baby?</TD></TR></TABLE>
you can do either, just drive it nicely down to the gas station, fill her up. Then open her up on the way home.
Re: (Vero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vero »</TD></TR><TR><TD CLASS="quote">
you can do either, just drive it nicely down to the gas station, fill her up. Then open her up on the way home.</TD></TR></TABLE>
any other opinions?
any other opinions?
if the motor was rebuilt then some say to baby it under 3500 rpm's for the first 500 miles or so..
Given your situation, i wouldnt worry about it and just go rip on it.
BodyKits NW
09-16-2007 03:23 PM
