my stero isnt getting enough power
Old Mar 4, 2002 | 05:00 PM
EGh22aEG's Avatar
Default my stero isnt getting enough power
i have a sony head unit hookedup wit two 6X9 speakers in the back and when i turn it up loud and have the lights on it skips if tthe car is idling.....and i have subs and an amp but dont want to put them in because it will never play.....the head unit display blinks when the bass hits,...does anyone know wat it could be?
Old Mar 4, 2002 | 05:10 PM
CmptchAV6's Avatar
Default Re: my stero isnt getting enough power (esp169)
sounds like your alternator isnt putting out enough energy for your car aka it is going bad. Take it to somewhere like autozone and have them check it out to see if it is putting out enough energy.
Old Mar 4, 2002 | 06:06 PM
Focal Energy's Avatar
Default Re: my stero isnt getting enough power (MugenCivicHX)
That or you have a loose power wire on the back of the radio. That's not a good sign at any rate. Better get your alternator tested and if that's not it, pull your radio to make sure your wires are all firmly connected and that you don't have any exposed wires grounding out on the frame of your car or any other metallic objects. You'll burn your car to the ground if it's the latter. Better hurry.
[Modified by Focal Energy, 10:07 PM 3/4/2002]
Old Mar 4, 2002 | 06:11 PM
CmptchAV6's Avatar
Default Re: my stero isnt getting enough power (Focal Energy)
doubt it is a loose wire and if it is he should of blown a fuse by now if he didnt do a fucked up job on the install anyways. My civic with a tiny *** alternator was powerful enough to run a Kenwood Z828, and a 4X225rms amp for my regular speakers and a 2X250rms for my subs all day long at idle so it is most likely his alternator is going out and that stuff tends to happen on cars. Also is your battery light on the dash comming on while the engine is running??? if it is something is definatly wrong with your cars charging system. If it isnt you have another problem and you need to go back and check all the wireing in the back of your stereo.
Old Mar 4, 2002 | 06:18 PM
Honestly, if it were his alternator that were going bad, and his radio wasn't getting enough power because of it, his car wouldn't run at all. If his radio is too much of a load for the alternator to handle, don't you think that would indicate that his battery was so dead that his car would have problems starting and running, let alone trying to run the radio.
Old Mar 4, 2002 | 10:54 PM
redblues's Avatar
New User
Ground the HU to the chassis. It's not the alternator or battery, it's a bad ground.
Old Mar 5, 2002 | 03:49 AM
Default Re: my stero isnt getting enough power (redblues)
Didn't think of that! Jeez!! I've been out of the audio scene too long! Good call!
Old Mar 5, 2002 | 07:39 AM
Jet Phi's Avatar
im just gonna tke my system out and rewire it cause i did a quick job its porbably a loose wire now that u say that ill go check thanks
JDMcivicSiEG6
Audio / Security / Video
Feb 1, 2008 05:17 AM
CivicBlack
Jan 23, 2006 05:16 PM
all*motor*d16z6
Aug 23, 2005 11:35 PM
JDMlyfestyle
12
Dec 10, 2004 04:24 PM
NonAutoX
Nov 27, 2003 02:20 PM
