clutch start?
Old Mar 3, 2002 | 10:11 PM
TurBoXBirD16's Avatar
Default clutch start?
hi, i am trying to install my remote starter...
i got everything wires correct, except....it doesn't start... haha...
but when i push the button on the remote and i MANUALLY press on the clutch, it will start... BUT THEN.... the remote keep on starting the car when i keep the clutch down, it will make the starter makes the "zkkkk" sound.....once i remove the clutch, it won't make a sound....
how do i get this working??
Old Mar 4, 2002 | 02:04 PM
nsxxtreme's Avatar
Default Re: clutch start? (xbird)
You have to bypass the clutch. On the newer integra's I believe there is two switches on the clutch you have to bypass. It's been a while so I don't remember.
Old Mar 4, 2002 | 02:22 PM
99VTECex's Avatar
New User
Default Re: clutch start? (nsxxtreme)
Start by bypassing the clutch... There are two switches on the clutch... One is for cruise control and the other is the clutch sensor. The one you have to bypass is the one that is the pain is the ***. It is at the top of the clutch.
Old Mar 4, 2002 | 04:20 PM
Default Re: clutch start? (99VTECex)
yes... i know where the switch is...
i have tried to use my hand to press on the button, then the car will start....
but how do i start it without my hand pressing it?// hehe
in other words, how do i bypass it using the alarm??
Old Mar 4, 2002 | 05:06 PM
nsxxtreme's Avatar
use a relay
Old Mar 4, 2002 | 08:34 PM
HOW??
i need some specific instructions plz
coz i dunno how a relay works
Old Mar 4, 2002 | 10:52 PM
STK B16's Avatar
pull off the plug on the clutch there is two.. one on the lower and one way up top of the clutch. unplug the top one and connect the two wires together. and thats it.. it will bypass it. do this everyday on customers cars at work
Old Mar 5, 2002 | 05:21 AM
nsxxtreme's Avatar
Default Re: clutch start? (Json79)
Be careful this completely disables the clutch kill, this would allow the car to start in gear. Which means you can start your car when its in gear with your keys. Just a warning.
[Modified by nsxxtreme, 9:09 AM 3/5/2002]
Old Mar 5, 2002 | 09:10 AM
STK B16's Avatar
nsx.. thanks for the touch up. forgot a bout the important part of it. HHHehehe
EGed up from the seat up
Apr 6, 2011 06:33 PM
kroze
Honda Civic (2006 - 2015)
31
Oct 2, 2006 07:43 AM
TEG777
Jul 31, 2005 10:33 AM
99cpevtec
Jul 15, 2005 02:27 PM
deviant1
May 7, 2003 11:26 AM
