Altenator noise in speaker's
Old 12-10-2004, 01:11 PM
JDMlyfestyle's Avatar
Default Altenator noise in speaker's
Man this is getting really annoying. How do i get rid of altenator noise? i dont even know where to begin on this. not very much of a audio guy.
Old 12-10-2004, 01:25 PM
Electrician
Deemeetree's Avatar
What audio do you have?
Old 12-10-2004, 01:41 PM
pb16b's Avatar
Default Re: Altenator noise in speaker's (JDMlyfestyle)
better grounding and keep the rca's seperated from the power wires.
Old 12-10-2004, 02:39 PM
Pioneer Premiere headunit dont know model #
Sony 6.5" in doors
No rear speakers
Infinity Basslink
Old 12-10-2004, 02:42 PM
khmboostedeh2's Avatar
Default Re: (JDMlyfestyle)
better grounds definately.
Old 12-10-2004, 02:56 PM
JforJonathan's Avatar
Default Re: (Jeterkm02)
are your rca wires running along with your power wire? if so, try and separate those. it should help
Old 12-10-2004, 03:02 PM
lYellowDragonl's Avatar
yup check grounds and a possibly a new power source? that what fixed mine so i dont know
Old 12-10-2004, 03:11 PM
IVI
IVI's Avatar
Default Re: (lYellowDragonl)
most likely the ground. if not the ground, then the amp is going bad.
get another piece of power wire, and just run the ground straight to the battery to the amp. if that eliminates the noise its the ground.
also when installing an amp/running wires. its always a good idea to run the power wire on one side, while the rca's get ran on the other side to prevent any interference.
i have my power wire going to the trunk from the left(driver) and 3 sets of rca on the right(pass).
what kind of amp are you using ?
Old 12-10-2004, 03:29 PM
snoochtodanooch's Avatar
Default Re: (IVI)
if your not using an amp, you have a bad ground.
if you are using an amp, you can have bad ground, rca's running next to power, or something else. If redoing ground fails, run ground back to battery.
ps. audio forum would give better response.
Old 12-10-2004, 03:32 PM
IVI
IVI's Avatar
Default Re: (snoochtodanooch)
^ im pretty sure i said exactly that?
civictildeath's Avatar
actually try hooking up speakers in the rear. ive seen that be the cause before. also try regrounding it
Old 12-10-2004, 04:13 PM
Steve-0's Avatar
Default Re: (IVI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">most likely the ground. if not the ground, then the amp is going bad.
enough said!!! this guy hit the nail on the head. very good information and suggestions.
Old 12-10-2004, 04:24 PM
SI-ER's Avatar
yeah its probably just the ground you should check all your wires
DillyD
Audio / Security / Video
23
02-06-2010 11:53 PM
abusedvtec
05-04-2008 09:56 AM
SYTFU Tommy.
18
08-14-2006 09:33 PM
CivicBlack
01-23-2006 05:16 PM
Devo94ac
11-08-2005 12:15 PM
Quick Reply: Altenator noise in speaker's
