clutch start?
hi, i am trying to install my remote starter...
i got everything wires correct, except....it doesn't start... haha...
but when i push the button on the remote and i MANUALLY press on the clutch, it will start... BUT THEN.... the remote keep on starting the car when i keep the clutch down, it will make the starter makes the "zkkkk" sound.....once i remove the clutch, it won't make a sound....
how do i get this working??
You have to bypass the clutch. On the newer integra's I believe there is two switches on the clutch you have to bypass. It's been a while so I don't remember.
Start by bypassing the clutch... There are two switches on the clutch... One is for cruise control and the other is the clutch sensor. The one you have to bypass is the one that is the pain is the ***. It is at the top of the clutch.
yes... i know where the switch is...
i have tried to use my hand to press on the button, then the car will start....
but how do i start it without my hand pressing it?// hehe
in other words, how do i bypass it using the alarm??
pull off the plug on the clutch there is two.. one on the lower and one way up top of the clutch. unplug the top one and connect the two wires together. and thats it.. it will bypass it. do this everyday on customers cars at work
[Modified by nsxxtreme, 9:09 AM 3/5/2002]
EGed up from the seat up
Apr 6, 2011 06:33 PM
99cpevtec
Jul 15, 2005 02:27 PM
