Is Fully Synthetic Oils overrated? Your opinions?
Old Oct 4, 2005 | 02:43 PM
trooper0641's Avatar
Default Is Fully Synthetic Oils overrated? Your opinions?
Is there really a big difference between the 2 oils, conventional vs fully synthetic? Like night and day? Is it really worth the extra $3+ dollars to go with synthetic since I change my oil every 2k anyways? Your thoughts on a turbo honda.
Old Oct 4, 2005 | 03:16 PM
JLHDOHC's Avatar
Default Re: Is Fully Synthetic Oils overrated? Your opinions? (trooper0641)
If I was going to Run fully synthetic oil over Conventional I would run like a 15.40w
or possible 20-50w reason why is that the synthetic oil is thinner than your average 10-40w. I was running castrol gtx use to change it every 2000 miles, rebuilding now so I am going to go with the Mobil 15-40w extended performance it says you can go 7000miles or so. I figured I would still change it 3000 miles and see how that does I have work with oil for awhile and I am hearing nothing but good comments about that oil my buddy has a SRT4 and he runs it in his car and when we change his oil its clean
Old Oct 4, 2005 | 03:17 PM
KeyserSoze's Avatar
http://my.prostreetonline.com/...id=18
Check that out.
Old Oct 4, 2005 | 06:21 PM
98TEG2NV's Avatar
mobil 1 10w30 fully synthetic
Old Oct 4, 2005 | 08:43 PM
JLHDOHC's Avatar
Default Re: Is Fully Synthetic Oils overrated? Your opinions? (KeyserSoze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeyserSoze &raquo;</TD></TR><TR><TD CLASS="quote">http://my.prostreetonline.com/...id=18
Check that out. </TD></TR></TABLE>
Isn't that stock Specs though, or does it even matter on high HP cars..
Old Oct 4, 2005 | 09:31 PM
2k.civic.si's Avatar
Default Re: Is Fully Synthetic Oils overrated? Your opinions? (JLHDOHC)
http://www.bobistheoilguy.com
Old Oct 4, 2005 | 10:07 PM
k24em2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JLHDOHC &raquo;</TD></TR><TR><TD CLASS="quote">If I was going to Run fully synthetic oil over Conventional I would run like a 15.40w
or possible 20-50w reason why is that the synthetic oil is thinner than your average 10-40w. </TD></TR></TABLE>
Not so. Synthetic and conventional must adhere to the same viscosity standards.
Old Oct 5, 2005 | 05:34 AM
vtec.dc2's Avatar
or possible 20-50w reason why is that the synthetic oil is thinner than your average 10-40w. I </TD></TR></TABLE>
doesn't have much to do with it being synthetic vs conventional, it more has to do with manufacturer cause some 5w30 are thinner than others, one way to compare would be to go by specs and test results like HTHS.
in general synthetic will outperform conventional, if you want to run oils like 5w40 15w50 5w50 10w60, you would Have to use synthetic. for turbocharged application 15w40 conventional in my experience penzoil can do the job during summer, but synthetic just works better. for non turbo everyday driver i stick with conventional 5w30
Old Oct 5, 2005 | 05:59 AM
Rory Breaker's Avatar
Default Re: Is Fully Synthetic Oils overrated? Your opinions? (2k.civic.si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si &raquo;</TD></TR><TR><TD CLASS="quote">http://www.bobistheoilguy.com</TD></TR></TABLE>
Changing your oil every 2k is not the answer. Finding the right oil that suits your motor and driving style does.
Josh303
Honda CR-V & Element
Jul 21, 2014 06:23 AM
SiYouLater
Acura TSX
Jul 27, 2007 02:36 PM
allshowallgo
Dec 2, 2003 06:53 AM
mickey513
Oct 5, 2001 10:11 AM
Mike D
Jun 23, 2001 07:26 PM
